help me finish my coffee table - walnut
Forum topic by ichbinpete posted 12-07-2011 08:25 PM 2389 views 1 time favorited 10 replies Add to Favorites Watch
View ichbinpete's profile
ichbinpete
110 posts in 2812 days
12-07-2011 08:25 PM
Topic tags/keywords: question trick walnut finishing
So I’m near finished with the coffee table I am doing for our living room. It is made out of walnut I brought down to TX from Ohio. It is going to have custom glass pieces on the top and I may do a chamfer on the underside or roundover/ogee on the top (open to suggestions here as well)
my big question is how I should apply finish and what I should apply. I would put the process as:
1. Easiest (noob friendly)
2. Best
3. Fastest
I do own the HVLP sprayer from Rockler, but weather seems like it may be an issue and I dont want to spray inside. That said, if this is suggested I think there are a few days over the next two weeks where it might be warm enough/calm enough to do this outside. I really want to show off/enhance the grain patterns while keeping it semi dark still. I have sanded it from 80-120-150-220-360 and have everything pretty smooth, understanding the walnut is very porous.
As always thanks for your help!
-- It is better to keep your mouth shut and appear stupid than to open it and remove all doubt.
10 replies so far
16276 posts in 4339 days
#1 posted 12-07-2011 09:39 PM
My suggestion: Wipe on a coat of Boiled Linseed Oil as per label directions. This is fast and easy, and will really highlight the grain.
After the BLO has cured for about 48 hours, wipe on about three coats of wipe-on oil-based satin polyurethane. Again, this is a fast and easy process. Allow to dry to the touch between coats.
If the finish feels “nibby” at all when you are done, wipe everything down lightly with #0000 steel wool.
ichbinpete
#2 posted 12-07-2011 09:42 PM
sounds like a plan. Are there any thoughts on the BLO for home depot (Klean strip?) or Lowes (Crowne?)
Also, whats the best way to clean the wood after sanding? Mineral Spirits I think i read somewhere? I did “raise” the grain with water prior to sanding….
View Bill White's profile
Bill White
5054 posts in 4081 days
#3 posted 12-07-2011 09:47 PM
Charlie has it.
WaterLox Original can be used as a brushing or wiping finish.
Do you want to stain? I don’t have a prob with the grain showing ‘cause I feel that it reflects the nature of the wood.
Just don’t hurry the finish whatever ya use. BLO takes a while to fully cure between coats. The Waterlox is that type of finish. Look it up.
Bill
-- bill@magraphics.us
View Gary's profile
Gary
9342 posts in 3553 days
#4 posted 12-07-2011 09:48 PM
If you’ve got a compressor, you can blow the sawdust away. You could wipe if after that if you want.
View horky's profile
horky
241 posts in 3051 days
#5 posted 12-07-2011 09:55 PM
I like using natural Danish Oil. Wipe on, wipe on again, wipe dry … just like the directions say. You can do several times to build the finish. Then finish with poly as stated above. I just did the first coat on this aquarium stand .. walnut with curly maple ..
View Earlextech's profile
Earlextech
1162 posts in 2811 days
#6 posted 12-07-2011 10:39 PM
Spray stain and shellac top coat with HVLP. Two coats of stain, wipe the excess with a clean rag. Three coats of dewaxed shellac cut 1:1 with denatured alcohol. Rub out with scotchbrite pad to sheen wanted then wax, using some elbow grease. Beautiful, easy to do and easy to repair in the future.
Bill White
#7 posted 12-07-2011 11:04 PM
I like Earl’s answer too. Shellac is one of my favs. One of the oldest finishes out there. Imagine that. Bug stuff makes a great finish. Kinda makes ya wonder who figured this out.
Bill
ichbinpete
#8 posted 12-07-2011 11:12 PM
what kind of shellac do you suggest if I go that route? Is Zinseer any good? I dont have a hobby store/Rockler/Woodcraft too close so if I can use a big box store item it’s easiest….
also, a couple people have mentioned staining. I would like to keep it more of a brown & tan(sap wood) color and avoid it looking reddish. suggestions or just stay with the natural color?
#9 posted 12-07-2011 11:13 PM
I’ve used that brand of BLO… no problem at all. Horky’s suggestion of Danish oil is good too. I find BLO cures a little faster, but either product will give you good results.
View gfadvm's profile
gfadvm
14940 posts in 2811 days
#10 posted 12-08-2011 06:12 AM
I like Charlie’s suggestion for ease of application and simplicity. I have found that Spar/MS wiped on pops the grain like BLO and eliminates one extra step. Does anyone else use this?
