1/2" x 105" timberwolf blade not cutting straight inside the wood.
Forum topic by Blackie_ posted 12-07-2011 03:49 PM 1633 views 0 times favorited 17 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4882 posts in 2476 days
12-07-2011 03:49 PM
This 1/2” timberwolf blade is the only blade that is giving me problems, when slicing through think 10” thicker wood this blade is all over the place in there and the only thing I can think of is that I’m not tensioning it tight enough, I have a 14” Grizz with the riser kit and when tighting the blade I start with a some what loose blade then 1/4 turns until I get the wobble out and a straight line but looking on the tension meter is not even showing on the 1/8 scale yet so that’s why I’m thinking I don’t have it tight enough, when I put my 3/4” It’s much…. tighter and have never had any problems with it. My experience with bandsaws in general is only a couple months so still in the learning curve.
Need some advise on this thanks
Blackie
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
17 replies so far
View Roger's profile
Roger
20923 posts in 2767 days
#1 posted 12-07-2011 04:10 PM
Is your upper and lower wheels co-planer? I would also check all your cool blocks, or bearings spacing. (a 1 dollar bill thickness). Also, you may want to slow your feed down. Maybe you are pushing too quickly. Let the blade do the work. Good luck.
View PurpLev's profile
PurpLev
8534 posts in 3612 days
#2 posted 12-07-2011 04:22 PM
the ”until I get a straight line” sounds like you are not even close to putting proper tension on the blade. are you using the finger method (push finger against blade to check deflection under tension) to check for tension or are you simply relying on what the tension gauge on the saw shows?
I never rely on any of those gauges on these saws myself, but use my finger to check the blade. so far so good.
View Eagle1's profile
Eagle1
2066 posts in 3028 days
#3 posted 12-07-2011 04:30 PM
I have to agree with the others here. I tighten my blade until its pretty tight. Then I raise the arm up all the way up.hen I start to tighten up the blade until I only move the blade sideways about 1/4 of a inch. There are also a lot of videos about tuning up your bandsaw. Hope this helps with the help of the others here.
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
View Donna Menke's profile
Donna Menke
617 posts in 4229 days
#4 posted 12-07-2011 04:31 PM
Tighten the tension until when you pluck the blade on the vertical support side of the machine it sounds like ‘twang’. I just put a new wood slicer blade on mine and I always use the same technique regardless of blade manufacturer. Whether a 1/16” or 3/4” blade this technique works for me. If the the blade goes ‘ting’ it is way too tight, and if it goes ‘thunk’ it is way too loose.
-- "So much wood. . .so little time!" www.woodworks-by-donna.com
Blackie_
#5 posted 12-07-2011 04:51 PM
@cr1 Blade is a 4 TPI
Sounds like from everyone I’m to loose didn’t know anything about the finger trick, thanks for that info.
@Roger I am using what came with saw and am using the paper thickness between the guides also gauging the rear guide as well.
View jmos's profile
jmos
823 posts in 2333 days
#6 posted 12-07-2011 06:38 PM
I’ve got two timber wolf blades also, although I haven’t used them extensively. It sounds like what Blackie was doing was following the procedure Suffolk Machinery outlines for their blades:
http://www.suffolkmachinery.com/six-rules-of-sawing/
They specifically state their blades take a lot less tension than most. I’ve used their method and ended up with tension that barely registers on the tension gauge for a 3/4” blade. I odn’t have problems with the cut wandering, but it does seem rougher than it should be. ??Next time I resaw I’ll crank it up a bit and see if htat helps.
-- John
View David Kirtley's profile
David Kirtley
1286 posts in 2961 days
#7 posted 12-07-2011 08:22 PM
Also with a riser kit, you might be at the capacity of the tension spring. I upgraded mine when I put the riser block. I used the Carter Cobra Coil. No issues since then.
View Jim Finn's profile
Jim Finn
2647 posts in 2885 days
#8 posted 12-08-2011 05:54 PM
I have the 1/2” Woodslicer blades and like them. Only problem is: they do not last very long. I find them to dull quickly and then cut as you describe. I resaw a lot of cedar and some oak. Sounds like you need more tension on your blade. These blades cut the best I have tried, so I just change them often…...$$$
-- Website is https://craftingcouple.com/
Donna Menke
#9 posted 12-08-2011 06:26 PM
I used to think the Timberwolf blades were the top of the line- and in general they are, but since trying the Woodslicer I’ve used it the most for resawing. It is sweet. If I don’t have that one I use the 3/4” Timberwolf which tensions just fine on my 14” Jet without riser block.
Note: I don’t do that much resawing, but when I do I like a good blade.
View Bertha's profile
Bertha
13521 posts in 2656 days
#10 posted 12-08-2011 06:29 PM
^I’m not a big Timberwolf guy either. I’ve had decent experience with small blades but the Woodslicer is clearly superior in my experience. The Lenox tri’s are my general blades.
Blackie_
#11 posted 12-08-2011 07:47 PM
I have no problems with 3/4” – 4 TPI it runs smooth and straight but of course I’m getting it much tighter, what I mostly resaw are logs, I’m running 11” – 12” dia hackberry and various other woods, slicing up 1 1/8” quarters. logs are generally 24” less in length.
Actually I was following the instrucstions that came with the darn saw, it states to lossen the tension until you see a wobble then using 1/4 turns increase the tension until no more wobble , I’m finding out now that’s a no no.
View MrRon's profile
MrRon
4710 posts in 3207 days
#12 posted 12-08-2011 07:59 PM
cr1: What saw are you running a 1” band on? Certainly not a 14” BS.
Donna Menke
#13 posted 12-08-2011 08:52 PM
WOW- cr1- you are hard-core!
Donna Menke
#14 posted 12-08-2011 09:07 PM
Blackie- I’m usually for following instructions to the letter, but that didn’t work for me with the so-called low-tension blades.
Blackie_
#15 posted 12-09-2011 02:33 PM
I’m assuming cr1 has a larger then 14” bandsaw. Thanks for that info cr1 I’ll look into a lower TPI, also with the blade I have, I didn’t think I was feeding to fast, maybe I was but what if I payed more attention to my feed rate on the 4 TPI would that help?
@Donna, thanks I see right now I have questions for you if and when we ever come together at a meeting table :) how about sometime after the holidays? The low tension blades I’ve not had any problems with using the tension method I mentioned.
