Blanket Chest lids
Forum topic by msparky14 posted 12-06-2011 08:00 PM 4971 views 0 times favorited 23 replies Add to Favorites Watch
View msparky14's profile
msparky14
26 posts in 2604 days
12-06-2011 08:00 PM
Topic tags/keywords: red oak blanket chest lids oak tip
First off, I’m a Novice at this whole woodworking thing. I had a shop class or two in high school (Don’t want to think how long ago that was.) I travelled alot with the military and collected several tools over the years and am just now trying my hand at a few projects.
I am currently making 4 raised panel blanket chests for my kids for Christmas. They are made from red oak, just over 3/4” thick, they measure 44×21 x 21. The lid is 44×21. My question is do I need strips of wood for braces under the lid. (Not exactly sure what they are called.) I have seen alot of pictures without them, but when I see a lid with them it makes me wonder if I the extra support/stability from these. Is there a rule of thumb for something like this? Is this just for looks mainly? I would appreciate any assistance you can throw at me.
-- ~ Mike ~
23 replies so far
View Gary's profile
Gary
9386 posts in 3673 days
#1 posted 12-06-2011 08:51 PM
First, welcome to the site. Second…not sure just what you are talking about. Where under the lid? What kind of brace? Are you working from a plan? Can you include a picture?
msparky14
#2 posted 12-06-2011 09:14 PM
This is NOT the blanket chest I am making, but it shows the braces/supports pretty well. (It’s the 3 wooden slats that run perpendicular to the lids grain.) I’ve seen some with 2 and some with 3 pieces.
I do have a plan, (It doesn’t call for these) I have altered it some but not to drastic. The lid is made of 13/16” red oak, three 44” long pieces 7” wide, routed a glue bit on the edges and glued together. I appreciate the help. Google and Yahoo didn’t show a whole lot, but it’s probably from my lack of knowledge or explanation.
-- ~ Mike ~
View Gary's profile
Gary
#3 posted 12-06-2011 11:06 PM
Those are often times put on to keep the top from warping, or separating…especially if that is two or three sections glued together.
View cabs4less's profile
cabs4less
235 posts in 3003 days
#4 posted 12-06-2011 11:20 PM
If you use the battons ( what i call them) make sure your screw holes are enlogated for wood movement ans its sup to you if you want to use them you can do bread board ends if ye worried about warpin and dont like the look of battons
-- As Best I Can
View Don W's profile
Don W
19050 posts in 2808 days
#5 posted 12-06-2011 11:53 PM
Note that piece is not raised panel. I assume you are going to make 2 or 3 panels per top? I don’t think you’d need the support strips. Add them only if you think they add a “cool” factor. Unless they are added correctly, they can cause the panel to split. Don’t glue them (or only glue one end) and make sure you elongate the screw hole a tad.
msparky14
#6 posted 12-07-2011 03:56 AM
Thanks for all the help.
Gary, I am pretty sure warping won’t be an issue even though there are 3 sections glued together. The wood was flat to start with and is 3 years old (At least) and doesn’t show any negative signs of twisting, warping or cupping. I am new, and could be wrong.
Cabs, I’m already past the bread board ends being an option. (Not that I can’t change it, just more work) Battons I’ll remember from here on out.
Don, The lid won’t be a raised panel, just a flat surface like what is in the picture. Thanks for the tip on the elongating the screw hole.
This site has helped me so much!!
-- ~ Mike ~
Don W
#7 posted 12-07-2011 03:59 AM
if your past the bread board ends being an option, sounds like there should be some pictures posted. :-)
bandit571
22024 posts in 2924 days
#8 posted 12-07-2011 04:25 AM
Just a look at one with a bread board edge:
msparky14
#9 posted 12-07-2011 05:08 AM
Here are couple pics with my cell phone. They are all the same, just will be stained different colors.
I just got done staining and sealing 2 of them and these are ready to assemble. Then the finish!
They are spread out on my garage floor (that’s all I have for work space.)
https://s3.amazonaws.com/vs-lumberjocks.com/lvtcn80.jpg!
-- ~ Mike ~
msparky14
#10 posted 12-07-2011 05:09 AM
-- ~ Mike ~
Don W
#11 posted 12-07-2011 01:49 PM
How are you raising the paneling and molding the stiles? Router table, shaper?
msparky14
#12 posted 12-07-2011 06:57 PM
I only have a router table. Being so new, I don’t see a need for a shaper just yet.
So far I am very pleased with the progress, (Even if my regular job keeps interferring with my hobbies)
I’m only concerned with the corners fitting as well as they did during the dry fit. They are 45 degree cuts with a snug spline to hold them together. ( I got that idea from a woodworkers journal magazine and I thought it look great. Hope I didn’t overstep my abilities to soon.) Should start the glueing process in the next day or so and can get you a “nearly” completed picture then. (Need to find a little slower drying glue to give me enough working time before I clamp them together.)
-- ~ Mike ~
View casual1carpenter's profile
casual1carpenter
354 posts in 2716 days
#13 posted 12-21-2011 11:33 PM
msparky14
‘First off, I’m a Novice’ .... I believe that is a major understatement.
I would be interested is seeing more pictures as this progresses. So far it looks like you are doing a great job. Was the plan yours or purchased? Not that I’m in the market for a blanket chest, but I do enjoy seeing fine wood work along with style and dimension ratio, etc as an artistic endeavor.
msparky14
#14 posted 12-22-2011 12:25 AM
Casual 1, I am a novice, really. I’m usually to busy to start any projects that are of real value. Usually my tools are for repairs around the house or yard. Like a small awning for for my shed doors to keep rain from running inside and soaking the floor. My biggest projects to this date have been a quilt rack and a handful of shadow boxes.
I appreciate the compliment, and yes I did purchase a plan from woodcraftplans.com (it’s the traditional American blanket chest.) I used their dimensions of 44 X 21 X 21, but altered it some. I didn’t want the drilled holes and wood plugs showing, so opted for a raised panel look with the corners being mitered at 45 degree angle and a spline to join them together. ( I got that plan from a woodworkers journal magazine I had, but I really liked the look it gives as being one pieces of wood, but what a hassle at assembling.)
Most of the project worked out well, with the help from so many forums at this site, as well as youtube videos. I had a few errors and it was evident from all the wood thrown throughout the yard at the time. (Just kidding) My biggest challenge was the lids. They were to large to crosscut on any tools I had, so I elected to use a circular saw with a straight edge as a guide. (Some how I measured wrong and was 3/4” short on all the pieces, and had to attach another board with biscuits, then rip them to the correct size.) My latest problem is attaching the hinges. I ordered hinges online, but the screws are cheap aluminum and twist off at the head half way into the wood. Yes I pre-drilled pilot holes! So I had accept what little Lowes had for an alternative since it’s crunch time. Thankfully, that’s all that’s left to do.
Attached are 4 pics, (No lids are attached, and one is removed to see the inside.) Once these are on, I just have to wait for Santa to show. Thanks again.
-- ~ Mike ~
msparky14
#15 posted 12-22-2011 12:27 AM
-- ~ Mike ~
