Cutting Board Question
Forum topic by MashMaster posted 12-06-2011 06:07 AM 1041 views 0 times favorited 3 replies Add to Favorites Watch
View MashMaster's profile
MashMaster
134 posts in 2660 days
12-06-2011 06:07 AM
I’ve built two cutting boards now and have had the luxury of having access to a large drum sander. I won’t have access to that anymore. How do you sand the boards flat on the end grain? It seems that a belt or orbital sander would leave a non-flat board.
-- - Dave ; Austin, TX
3 replies so far
View flossy's profile
flossy
103 posts in 2371 days
#1 posted 12-06-2011 04:53 PM
I’ve used a belt sander to get everything flat, then cleaned up with orbital and in-line sanders through smaller grits.
My process with a belt sander involves initial strokes at an angle (say, 15°) and overlapping the strokes until I’ve covered the entire surface and back again. Then I will shift the angle in the opposite direction and repeat. I continue this process until everything is flat, then I remove those scratches with a traditional straight-on stroke.
At that point, everything should be dead flat and it’s just a matter of removing finer and finer scratches.
-- http://www.ricketyfurniture.com
View chrisstef's profile
chrisstef
17386 posts in 3006 days
#2 posted 12-06-2011 05:15 PM
Some guys like to set up a router jig where it rides on 2 parrallel rails.
View BreakingBoardom's profile
BreakingBoardom
615 posts in 3081 days
#3 posted 12-06-2011 06:30 PM
To see what chrisstef is talking about, you can check out Gary Fixlers cutting board and jig HERE.
-- Matt - http://breakingboardom.wordpress.com/
