Low luster finish on walnut
Forum topic by Dhoagy posted 12-05-2011 05:55 PM 1127 views 0 times favorited 2 replies Add to Favorites Watch
View Dhoagy's profile
Dhoagy
1 post in 2773 days
12-05-2011 05:55 PM
I just completed a Parsons Table and matching bench out of black walnut. I have Applied an analine dye to even out the color. I plan to apply a coat of Boiled Linceed Oil next to help pop the figure than a shellac sealer followed by a Glaze for highlighting. I am looking for a low luster top coat to apply over all this. Any ideas?
2 replies so far
View tenontim's profile
tenontim
2131 posts in 3826 days
#1 posted 12-05-2011 06:34 PM
Sounds like you’re over doing the finishes. If you put dye on it, you’ve already muted the natural grain and figure, so I would just go with several coats of blo, if that’s what you already have. personally, I would use 100% tung oil instead, about 10-12 coats. That will give you a fairly protective finish that’s also low luster.
View Bill White's profile
Bill White
5007 posts in 4042 days
#2 posted 12-05-2011 09:12 PM
I would rethink the process.
Here’s what I’d do:
Sand well to about 220, seal coat with a shellac wash coat, stain if ya want, finish with a wiped varnish.
I use Modern Masters satin poly. Buff with wool or a non-woven pad and wax.
Understand that poly is not one of my favs unless the workpiece is gonna be a high-use object.
I don’t often stain walnut ‘cause I like the varied colors. Oh well…....
Bill
-- bill@magraphics.us
