| Forum topic by Logan Craig | posted 532 days ago | 1405 views | 0 times favorited | 18 replies | ![]() |
532 days ago |
Topic tags/keywords: box box joinery hinges barrel barrel-hinge barrel hinge drill drills precise drilling mounting hinges hinge question I bought the Porter Cable dovetail jig some time back and have been practicing box and drawer construction with an intent to graduate into smaller and thinner jewelry-style boxes. But for now I’m working with cheap 1” whitewood. So here’s my question: http://www.leevalley.com/US/hardware/page.aspx?p=64335&cat=3,41241,41265 I bought the 12mm ones. I cannot seem to get the holes PRECISELY where necessary. I have a Delta drill press that I can’t really brag about, but I think it should be functional for this purpose. My box construction is such that I am trying to mount the hinges into the ‘sides’ (the 1” dimension) of both the lid and the box. Another issue is that I have no metric drill bits. I have an HSS bit that is 31/64ths that I’ve been using and it seems like a good fit. However, the HSS bit is very difficult (for me) to center over my mark. It also seems to ‘crawl’ around as the bit descends into the wood, despite the soft wood and drill press. So I’m thinking I need a bit that goes where its told better. I love Forstner bits, but haven’t found any in the rather oddball size I need. Would an auger bit be a good choice? I’ve never used them. Something else? I’m not categorically against getting a metric bit set, but the hinges sat pretty happy in the 31/64ths hole. What do you guys think? Incidentally, these hinges are very cool and of solid construction, I highly recommend them if you can figure out how to install them better than I :) Thanks for the help! -- Logan, Virginia |
18 replies so far
#1 posted 532 days ago |
Thanks WudnHevn, I did try that, but found the next size up was chewing into the hole somewhat randomly and not following the guide hole as well as I’d have liked. Maybe I should take smaller steps though. I’ll try again tomorrow taking more (smaller) steps. -- Logan, Virginia |
#2 posted 531 days ago |
Brad point drill should work. You might need to drill a smaller pilot hole to start with. – http://www.amazon.com/Timberline-606-154-Brad-Point-Drill/dp/B000P4OQYW -- Joe |
#3 posted 531 days ago |
You might try a center punch. Then you can put the center spur into the dimple, so less likely to skate. This is the same way you start drilling a hole in metal, but it works in wood too. Especially good in end grain and really hard woods. If you don’t have a center punch, give an awl or small phillips screwdriver a good whack. -- Karen - a little bit of stupid goes a long way |
#4 posted 531 days ago |
Logan, -- Government does not solve problems; it subsidizes them. |
#5 posted 531 days ago |
Or to solve your problem and save a lot of hassle: By the way, make sure the drill press table is as close to being perpendicular as possible to the quill. Indicate if possible. -- Government does not solve problems; it subsidizes them. |
#6 posted 531 days ago |
Why not use a Transfer Punch to set the exact center of the place you want the hole to be? http://www.harborfreight.com/28-piece-transfer-punch-set-3577.html
-- Improvise.... Adapt...... Overcome! |
#7 posted 531 days ago |
The recommended bit size for the 12mm barrel hinge is 12mm or 15/32”. You can purchase individual drill bits (Brad Point/Forstner) in those sizes from Lee Valley. |
#8 posted 531 days ago |
I’m with Joe with the brad point bits. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#9 posted 531 days ago |
center punch the hole first then use a brad point bit centered on the dimple left from the punch. make sure you work part is clamped securely to the DP table/fence. -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#10 posted 531 days ago |
If you do not have a center punch to start with and have to start with a smaller bit, then make sure that that bit is SMALLER than any brad point you are thinking of using after starting the hole. The last thing you want is to NOT have any meat for the brad point to guide from. If you have eliminate all of the material around the brad point it won’t center properly. -- HorizontalMike -- "Woodpeckers understand..." |
#11 posted 531 days ago |
The older I get, the more I realize it is nice when I can use the right tool for the job. Look up “Vix Bits”. They are self centering and are made for drilling holes for hinges etc. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
#12 posted 531 days ago |
Hi LC, Most of the above suggestions will work fine if you are working with steel or other metals. However with wood if you use a guide of some sort to “guide” the drill to where you want the hole. You can use a piece of maple to make a guide or if you have lots of holes then a piece of steel would work best as you won’t wear the guide out as quickly. Maple drills well with sharp tools and the bit doesn’t have tendency to follow the grain. To make a wood guide drill the holes first at the linear spacing you want between the two hinges and then glue a strip of wood along side of the holes to act like a fence to position the guide on the side of the box. Much easier to sneak up with fence to the holes than drill the holes in the right position in relation to the fence. You could incorporate stops on one end of you guide block so you holes are positioned where you want them in relation to the end of the box. Clamp your guide to your box and drill the holes with a brad point the correct size. You can make you own brad point drill from a regular twist drill, use a disc grinder with 1/16 thick cutoff disc and copy the pattern from larger store bought brad point. A deft hand helps, if you screw-up cut the sore end of the drill and start again, HSS twist drills are cheap. Clamp the drill bit in a vice and shape the business end until you happy with the outcome. Hope this helps. Thanks jb -- Playing with wood and metal for the last 50 years, driving and building Land Cruisers for the last 40. Experience is what you get when you don't know what you are doing. |
#13 posted 531 days ago |
The one thing that I have learned with since I started working with metal is to always use a center drill. If you are not familiar with them:
These short stubby drills will not deflect. Then once you have the hole spotted, follow up with a regular bit. Since you are drilling wood, I really wouldn’t suggest the drilling up in steps. The guide mentioned by JB is a better way. The reason is that the wood is soft enough that you can cut to the side with drill bits (just not dependably.) Go ahead and go for the full size because it is less likely to deflect. Thicker bits don’t bend like thin ones. Clamp well and hold everything stable. -- Woodworking shouldn't cost a fortune: http://lowbudgetwoodworker.blogspot.com/ |
#14 posted 531 days ago |
Brad point. You didn’t say whether you were using a hand drill or a Press. The nice things about brad points is ( a) you can make ‘em yourself with either a dremel with a cut off wheel or a metal cut off blade ( for the larger diameter drills) and (b) the point tends to stay where you put it and follow nicely into the wood without wandering off the line as it encounters harder and softer grain patterns. Twist drills have a web. The web requires that the drill is always pushing material out of the way at the center. As the drill encounters softer wood, the drill tends to follow the path of least resistance. You can easily get funny shaped holes -- When the moderator chooses sides, his site sucks. |
#15 posted 530 days ago |
Thanks for all the help. I found a nice set of brad point bits at the Harbor Freight outlet and got the holes perfect on my first try. I’ll still be keeping an eye out for a good 16th inch increment forstner bit set. I posted the completed box in projects. thanks
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3542 |
15752 |
Hand Tools
2028 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
