T Track??
Forum topic by idiotstick posted 12-02-2011 11:15 PM 2759 views 0 times favorited 9 replies Add to Favorites Watch
View idiotstick's profile
idiotstick
28 posts in 2930 days
12-02-2011 11:15 PM
Does anyone here in uk know where I can buy T-Track??
Many thanks.
Pete.
9 replies so far
View DSH's profile
DSH
15 posts in 3295 days
#1 posted 12-03-2011 12:59 AM
Rockler and Woodcraft both carry it on-line and in their retail stores.
-- Give me six hours to chop down a tree and I will spend the first four sharpening the axe. Abraham Lincoln
View HorizontalMike's profile
HorizontalMike
7770 posts in 3152 days
#2 posted 12-03-2011 02:59 AM
At 80/20 Inc.
1050 is a thin .50” x 1.0” T-slotted aluminum profile made from 6105-T5 aluminum. This profile has one open T-slot and is compatible with all 10 Series fasteners and accessories.
Part No. Finish lbs. / Ft. Stock Length Moment of Inertia Area
1050 Clear Anodized .3679 145 In. IX= .0074”4
IY= .0323”4 .3161”2
View David Kirtley's profile
David Kirtley
1286 posts in 3236 days
#3 posted 12-03-2011 07:12 AM
Peachtree and Incra as well.
View wingate_52's profile
wingate_52
226 posts in 2807 days
#4 posted 12-03-2011 12:44 PM
Axminster have a couple of sections. I have their cheap blue series. They also sell Kreg T-Track.
Rutlands sell another section.
View richgreer's profile
richgreer
4541 posts in 3312 days
#5 posted 12-03-2011 11:39 PM
Maybe this is not the response you wanted but I will share this experience with you.
I thought I wanted a T-track for a music stand I was building. Then, someone on this board suggested I cut the t-track myself directly into the wood with a router.
I tried that and I am very happy with the results
http://lumberjocks.com/projects/53374
Be advised that you need to initially make one or more passes with just a straight bit. Then use the special “winged” bit to cut the t-track. There is too much material to clear out if you just use the special t-track bit.
This approach would not work in every application, but it worked great for my music stand. You will see that I have both a straight t-track to set the height and a curved one to set the angle of the music stand top.
wingate_52
#6 posted 12-04-2011 02:28 PM
I have routed “T-Track” from within the wood. I got my bit from MCLS. I have also made it, by cutting 2 grooves of different widths. Inlaying a strip of birch ply, and then running a groove through the ply.
View brtech's profile
brtech
1054 posts in 3160 days
#7 posted 12-04-2011 05:26 PM
Orange Aluminum. Best price on the net for the 1/4” size. Like a 4’ section for $7.12.
Good quality, easy to deal with. Standard problem of shipping costing as much as the item if you only want one. If you need several sections, it’s great.
wingate_52
#8 posted 12-04-2011 07:27 PM
Mine is also on a router fence.
idiotstick
#9 posted 12-04-2011 08:37 PM
Thank you all for your help, I am going to try the “Cut your own route” first.
Pete.
