How to glue wood to steel?
Forum topic by b2rtch posted 12-02-2011 04:44 PM 23380 views 0 times favorited 14 replies Add to Favorites Watch
View b2rtch's profile
b2rtch
4861 posts in 3071 days
12-02-2011 04:44 PM
Topic tags/keywords: question
I am making oak “covers” to put around metallic electric boxes.
In the past I have used spray on 3M contact glue to glue them, it made a huge mess.
Then I used Gorilla, it does not seems to hold very well.
Then Liquid Nail, it drips all over the place.
What would you use?
Thanks
-- Bert
14 replies so far
View nailbanger2's profile
nailbanger2
1041 posts in 3166 days
#1 posted 12-02-2011 05:03 PM
I have used liquid nail and you are right, it’s messy. I think I would try epoxy and lots of masking tape, green chemical resistant masking paper, and drop cloths. I’ve never tried it though.
-- Wish I were Norm's Nephew
View Bertha's profile
Bertha
13529 posts in 2716 days
#2 posted 12-02-2011 05:05 PM
I’d probably drill a few shallow holes in the wood, scuff up the metal, and use epoxy. Liquid nails has been hit or miss with me. I’ve had it dry up and break free with temperature changes. Now I just use it to fill carpenter bee holes, lol.
View tenontim's profile
tenontim
2131 posts in 3767 days
#3 posted 12-02-2011 05:11 PM
Try the 100% silicone caulk. That stuff will hold about anything.
View kizerpea's profile
kizerpea
774 posts in 2390 days
#4 posted 12-02-2011 05:18 PM
POLYURETHANE…GO TO NAPA AUTO PARTS. ITS IN A CAULKING TUBE..ITS USED TO INSTALL AUTO WINDSHIELDS.. THAT WILL GET IT DONE!
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
View Jeff's profile
Jeff
439 posts in 3217 days
#5 posted 12-02-2011 05:42 PM
+1 to the silicone. Plus if you ever need to remove it in the future, a little effort will allow you to. And it’s thick enough that it won’t get all over everything.
View DS's profile
DS
2924 posts in 2443 days
#6 posted 12-02-2011 05:45 PM
Polyurethane construction adhesive is available at your Big Box Home Store. It works similar to Liquid Nails, but adheres to many more types of material and is more rigid.
This is particularly useful with stone, concrete and wood surfaces and is super strong when cured.
b2rtch
#7 posted 12-02-2011 05:52 PM
Thank you all
-- Bert
View Nomad62's profile
Nomad62
726 posts in 2981 days
#8 posted 12-02-2011 06:01 PM
I have used silicone automotive sealers for various glue-ups, it works well on almost anything; the only problem is its flexability, it tends to break down and off after some bumping. I think I would tend to use a good dose of hot glue sticks. Long time ago there was a product called “Shoe-Goo” that was the best glue for anything at all. Thick and sticky, it cured into hard rubber. Haven’t seen it for a while tho.
View MrRon's profile
MrRon
4793 posts in 3266 days
#9 posted 12-02-2011 06:30 PM
You should wipe the electric boxes well with a solvent, like acetone or alcohol. Some adhesives don’t adhere well to a galvanized.
View richgreer's profile
richgreer
4541 posts in 3097 days
#10 posted 12-02-2011 06:56 PM
Any time a question comes up about what glue works best for a given application, check out this website – -
http://www.thistothat.com/
View jerkylips's profile
jerkylips
416 posts in 2593 days
#11 posted 12-02-2011 07:01 PM
could you drill through the metal & screw into the back of the oak? that way you wouldn’t have to worry about adhesives failing..
b2rtch
#12 posted 12-02-2011 07:03 PM
Thank you all
—Bert
-- Bert
View Lee Barker's profile
Lee Barker
2170 posts in 2873 days
#13 posted 12-02-2011 08:54 PM
Shoe Goo has a relative in E6000 and whatever equivalent a crafts place like Michael’s has. (It will have an alphanumeric name.)
These products are a little easier to spread than silicone of the GE lineage.
There are also incredible double stick tapes, like those used for auto trim. If your surfaces are smooth and clean enough, these are totally unmessy.
Kindly,
View Grandpa's profile
Grandpa
3259 posts in 2698 days
#14 posted 12-02-2011 09:08 PM
I used a polyurethane adhesive that came in a tube about like a tooth paste tube in size. It was labeled as
“Better N Nails” I believe. It was an excellent product. I put it in a stripped out hole in an oak door and put the screw in then let it cure. It is still holding 15 years later. I know it really should have had the hole drilled out and a dowel put in then a new pilot hole drilled but I was on a mission at the time and it worked. I would look for something like that.
