Surfacing after dyeing
Forum topic by brtech posted 12-02-2011 01:21 AM 696 views 0 times favorited 1 reply Add to Favorites Watch
View brtech's profile
brtech
1049 posts in 3097 days
12-02-2011 01:21 AM
I’d like to build a box that has a glue up top/sides, where one of the component parts is a dyed wood, probably oak. I’m expecting that I’ll have to surface the glued up panel (planer and/or sand). Can I do that AFTER dyeing?
I’m not too concerned about the edges, I’m mostly concerned about the surface.
1 reply so far
View fussy's profile
fussy
980 posts in 3225 days
#1 posted 12-02-2011 02:26 AM
Do most of your surfacing/sanding before dying. You’ll have to do a little fine sanding after, but it should be minimal. You want the surface smooth so the dye is consistent and not blotchy. If you are using water-based dye, raise the grain first, and fine sand before dying. It gets harder to do after, so I’m told.
Steve
