end grain sanding of a cutting board re-finish...HELP
Forum topic by Napaman posted 574 days ago 189 views 0 times favorited 5 replies Add to Favorites Watch
Rockler
View Napaman's profile
Napaman
3495 posts in 977 days
574 days ago
Topic tags/keywords: end grain sanding cutting board question
Hey everyone…
the beginner here is still working on his neighbors cutting board…and I am worried about sanding the end grain of this cutting board…
I only have a quarter-sheet sander and not an orbital sander…I have sanded the entire cutting board down…rounded the corners as prescribed, routed a new “gutter” for blood and gotten rid of some black marks on the bottom…it is all looking and feeling smooth…
I have two things left…fill some small cracks on the bottom (going to use CA glue and sand with 220 as suggested by several people) AND…
finish sanding the END GRAIN...I cant seem to get it any better and I am getting worried that I am doing something wrong…I watched the WoodWHisperer’s video on making an end grain cutting board and he made a comment (something to the effect of): “it will take longer to sand this board since it is all end-grain…but keep sanding it will improve…”
SO after watching that video fri night I kept going on the sanding of the end of this cutting board after I finished everything else…again the entire board is NOT an endgrain board…I just have the two ends to worry about…but right now they look kinda chalky as opposed to nicely sanded…
any suggestions…would love it…
thanks for the read…
View Tony Z's profile
Tony Z
173 posts in 690 days
574 days ago
Get a belt sander or an orbital sander. I just finished another one of these today. I start with the belt sander with 80 grit and then use the random orbital going from 100, 150, 220 grit. I also used a scraper and that really smoothed things out. A 1/4 sheet sander just isn’t aggressive enough to tackle that end grain. I’ve also run them through my surface planer. I glue a sacrificial piece of wood to the trailing end of the cutting board so I don’t chip out the end of it. After it’s smoothed out, I just rip the sacrificial piece off on the table saw and sand down the edge. I hope that helps.
-- Tony, Ohio
Napaman
574 days ago
thanks tony…
View grumpycarp's profile
grumpycarp
232 posts in 646 days
574 days ago
Keep dropping down to finer grits. Go to 320 or 400 and maybe even 600. Keep switching out the paper, lots of folks I know don’t change the paper often enough and the result is a muddy finish. Paper is cheap, time is not.
The rule of thumb is to go at least one if not two steps further on endgrain.
View Tony's profile
Tony
814 posts in 930 days
573 days ago
Use good quality sand paper – cheap sand paper does not last as long and you use a lot more, you should not need to go beyond P320.
When finishing the board, apply some extra coats to the end-grain 1st- wait utill its dry and rub it out with P320 or wire wool, after 2 to 3 coats on the end, start on the whole board. You can get a really high sheen using this method.
Napaman
573 days ago
thanks guys…
