Powermatic 8" jointer
Forum topic by tbone74 posted 12-01-2011 07:31 AM 1477 views 0 times favorited 5 replies Add to Favorites Watch
View tbone74's profile
tbone74
64 posts in 2358 days
12-01-2011 07:31 AM
I was wondering if powermatic made an 8” jointer that was 115 volts? I have been looking on the internet and I can only seem to find 230 volt. I have found one for sale and they say its 115 but it’s quite a distance and I really don’t want to waste a trip..
Thanks for any input
-- Tony
5 replies so far
View Loren's profile
9765 posts in 3521 days
#1 posted 12-01-2011 07:54 AM
Not inconceivable. Voltage has to do with amperage. Maximum amps
for 110 volts is about 18 on a normal household circuit, so the horsepower
of the motor would be 1.5 – which is fine for an 8” jointer.
If you’ve got a 2hp motor chances are it’s going to pull 22 or 24 amps
on a 110 volt circuit, which is too much for a standard circuit. Thus,
the load is split and it becomes an 11 or 12 amp load on a 220 volt
circuit.
If the seller claims it’s 110 volt have him check the amperage on the motor
plate to be sure.
View doordude's profile
doordude
1085 posts in 2856 days
#2 posted 12-01-2011 08:26 AM
i don’t think an 8” jointer is going to run on 110 volt circuit. thats a lot blade to run for fine cuts on 110 volts. you can get 6” that will run on 110. don’t you have a electric dryer? you could make up a 8 gauge extension cord to run the 220 volt jointer. just a thought.
tbone74
#3 posted 12-01-2011 09:07 AM
Gas dryer, no room in the pannel for a 220v breaker. I emailed the guy asking for the specs of the motor and the model of the jointer….we will see
-- Tony
View ChuckV's profile (online now)
ChuckV
3084 posts in 3400 days
#4 posted 12-01-2011 03:26 PM
My Delta 8” jointer is 1.5HP and can be wired for either 110 or 220. I have never felt that it was underpowered, even when face jointing an 8” wide board.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View Bertha's profile
Bertha
13495 posts in 2566 days
#5 posted 12-01-2011 04:07 PM
I’ve got the 6” PM at 110V for what that’s worth. It feels adequately powered but I hate the wing adjustment. I will say that it’s remarkably quiet when idling. Like shockingly quiet.
