Grizz planer- putting chip braker on
Forum topic by BrianA posted 12-01-2011 04:22 AM 894 views 0 times favorited 1 reply Add to Favorites Watch
View BrianA's profile
BrianA
76 posts in 2993 days
12-01-2011 04:22 AM
I have a Grizzly 15” planer made under another name. I got it used worked OK but needed to change the blades, So I thought I would clean it all up and pulled the rod out that holds the chip breaker. It slipped out easily but now I want to put it back and the rod is difficult to thread thru the “rod holder tube” and I cannot get it into the hole to put the nut on to finish it. the chip break sits against the anti kick back bars and they will not lift when I try to push them up so stock will not go thru.
Does the aniti kick back rotate so that the rod will slip past?
Not sure if I made myself clear or not, but hope someone has taken that apart and can help.
Brian
Milwaukee
1 reply so far
BrianA
#1 posted 12-08-2011 01:50 AM
I did figure it out. Operator error:-) When I put the chip breaker in I need to slide it along the top of the anti kick back tabs and then it all dropped into place.
Brian
