Need help building a floating deck under pergola
Forum topic by bullseye posted 65 days ago 443 views 0 times favorited 2 replies Add to Favorites
View bullseye's profile
bullseye
4 posts in 168 days
65 days ago
Hello folks,
I need help/advice in building a floating deck 7” off the ground in this pergola structu
We just need it as a place where we can sit down with our patio furniture, instead of the uneven grass. I am looking to incorporate the 4 6×6 posts I already have in place.
Please advice on materials needed and if I need a concrete deck block?
Something like this one they have outside my local HD
View Garyswood's profile
Garyswood
50 posts in 111 days
64 days ago
Get the deck blocks and sink them a little, then fram teh floor like you would for any deck. You can run a 2×6l edger board to each post, with a deck block at the center of each. Assuming 12×12 floor, put a deck block in the center on top of a 8×16x16 footer(concrete blocks or poured). Run a 2×6 to divid ethe floor area in two then run your joists perpendicular to that at 16” centers. Your decking should be run perpendicular to the joists of course. If you sink your deck blocks a you should be able to have the deck top 7 – 8 inches above ground depending on how flat the area currently is. My reason of the large footer at the center is because you have the full diaphram of the deck loading it. The side 4 blocks and the posts are taking the perimeter load. which would be pretty small.
-- Gary, Matthews NC
View bman's profile
bman
1 post in 279 days
32 days ago
not sure where you are from but in franklin county nc you can’t use the deck blocks on any deck 6’x6’ or larger and will req a permit they require poured footings check your local code before you proceed can get costly for the penaltys “guess how i know that ?$$$$$$$
barry in NC
Bookmark And Share This Page
