11-30-2011 05:03 PM
Topic tags/keywords:
maple
transfast
finish
question
Hello! First time poster long time lurker, and being as I am about to finish my largest project to date, I figured I should sign up and say hi.
I’ve built a shelving system for under our wall-mounted TV, it is two-tiered. The bottom row of sheves is 6 feet long, the top is 4 feet. It is constructed completely of maple (no ply). I’ve decided to go with this Transfast dye to finish it :
http://www.woodcraft.com/Product/2000760/2571/HOMESTEAD-TransFast-Dye-Powder-Extra-Dark-Walnut.aspx
My plan is to give all the pieces one final sanding to 220 grit, then apply the dye liberally with a sponge to each piece, squeeze out the sponge, and wipe off, sand with 320, and repeat as necessary until I get my desired color. The product description says it can be top-coated with just about anything. Any suggestions? I would like some gloss to it, but not something that looks super thick. Something like this sheen :
I’m new to all of this, so I’m open to all sorts of suggestions or critiques about my approach.
Thanks!
7 replies so far
#1 posted 12-02-2011 02:30 AM
If you’re looking for easy, wiping varnish or shellac. Control the gloss of either by rubbing down the last coat with 0000 steel wool and paste wax.
Steve
#2 posted 12-02-2011 02:56 AM
I don’t mean to discourage you, especially since you are a first time poster. However, the best advice I can give you on dying is “don’t”.
#3 posted 12-02-2011 03:22 AM
Ed – First, welcome aboard. In response to your question, I dye a lot of maple and am currently finishing a set of curly maple cabinets using Mosers Analine Dye 844890 W1560, Lt Golden Br Walnut, Water Soluable. I have used this dye almost extensively on maple. You can mix it in various concentrations with water for varied result tending toward the golds and browns. It is quite effective in bringing out the figure in maple, especially curly maple. I usually put on the first coat over wood that has been sanded to 180 grit (the higher the final bare wood sanding the less absorption). I usually put on two coats for even coverage sanding with 320 between coats. After drying overnight I usually sand with 320 to 400 grit then go with a coat of dilute shelac (one part Seal Coat shelac sealer and one part alcohol). Rub this down with 00 steelwool then go with 3 coats rubbing polyurethane. I use one part Minwax Semi Gloss Polyurethane to one part mineral spirits. Let the final coat cure overnight then apply Minwax Finishing Wax with 0000 steelwool and buff. This should give you the finish you are looking for.
-- Roger M, Aiken, SC
#4 posted 12-02-2011 03:57 PM
Thanks for all of tips! I put down 3 coats of the dye on a scrap piece last night and got results that I liked, tonight I am going to apply the shellac to the test piece and see how it turns out. I was wondering what to put on top of the shellac as a final coat, and I think I am going to give Roger’s suggestion of poly/ms a shot.
Rich – I did some searching and the general consensus that I got was that dye was going to be my best option for a wood such as maple with very small pores. If the best advice you can give is “don’t”, that’s not very helpful at all and doesn’t add anything to the discussion. Care to elaborate?
#5 posted 12-02-2011 09:01 PM
Bing,
I had the first reaction to the idea of dying wood that Rich did. Don’t. I am going to guess it is because he feels, like I do, that once you dye wood, your done, and there is no going back. You better be happy with the results, ‘cause whatcha see is whatcha get.
I dye my finish. If I screw that up I can always strip it and try again. I use water base finish and dye so it’s easy.
Then again, I don’t dye that much in the first place… ;)
Rich, is that what you meant too?
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
#6 posted 12-02-2011 09:08 PM
Thanks for the input Milo. That makes more sense, the reason I went with dye is because I wanted something that would go into the wood and really let the grain show, so with that I understand the risk you point out that comes with doing such. I’m still experimenting on a small scrap piece, and once I think I have the finish I want, I am going to do a larger piece (I have a left over 10”x15”x3/4” piece) for my final test run. I’ve done some smaller projects before and have used water-based finishes, never with dye, I just decided that I’d like to try something new. I do think that dying the wood before final assembly sound make it somewhat easier, since they are all flat pieces.
#7 posted 12-07-2011 08:41 PM
Just an update, I applied the dye yesterday, and I am pleased with the results. Next will come a coat of amber, then clear, shellac. I tried a couple different methods of applying the dye on some test pieces, and the one that ended up working best for me was using a 4” foam brush to apply the dye. The first coat was light, and sanded down a bit with 320-grit to emphasize the grain. Then 2 normal coats and I got results that I was very pleased with.
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
12031 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2108 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
431 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
340 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1370 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
4905 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
6695 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
28061 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
212 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
5411 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1420 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
6233 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1388 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2154 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1187 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
4757 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2200 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
8845 |
