What would you do with a 13' fence?
Forum topic by Alexdi posted 11-30-2011 11:35 AM 1030 views 0 times favorited 8 replies Add to Favorites Watch
View Alexdi's profile
Alexdi
21 posts in 2313 days
11-30-2011 11:35 AM
Topic tags/keywords: fence
I recently bought a right-tilt Unisaw that came with a used Jet Xacta II fence with 13’ rails. My question is whether to install it as-is, cut it to size and sell the remaining rail pieces, or sell the whole unit and buy something shorter.
The fence is a Beisemeyer clone and about as heavy and solid as such things get. I wouldn’t have any reason to upgrade it. The two rails combined probably weigh north of 100 lbs. My shop is 17’x22’ with an 8” column near the middle. I plan to build a router extension for the saw with an extended storage cabinet underneath as is common.
The largest thing I can imagine ripping is a 4×8 piece of plywood in half, which would take 48”. I could also forsee wanting to make a beveled cut on the left side of the blade at the same width. With a few inches of margin, that’s something like 100”, which would leave 56” rail remnants still longer than most commercial fences.
Another person suggested that cutting such large rails would be a bit of a travesty. I’ve no idea what they’re worth in one piece or who might be interested in them. I can’t find any rails from any manufacturer of this length, though they appear OEM JET and not a custom job. By the same token, I can’t find 100” rails that would leave me all that left-side bevel capacity (which is primarily just to avoid kickback from binding against the fence with the right-tilt blade).
It seems to me the most efficient solution is to hang on to it and cut it. Or am I looking at this the wrong way? How much rail length is really necessary? Is this so valuable that I would be foolish to ruin it?
8 replies so far
View ajosephg's profile
ajosephg
1880 posts in 3466 days
#1 posted 11-30-2011 12:38 PM
I can’t see how having those long rails in a 17×22 shop.
I’d try to sell them on Craig’s List or E-Bay, or (?_ and use the $ to buy a “normal” length. If they don’t sell, then cut them down.
I would make the selling price the same $ that short rails would cost, so you don’t lose any money.
I have a shop similar in size to yours (16×30) and get by with rails as shown in these photos.
http://lumberjocks.com/ajosephg/workshop
Since I work alone and am getting up in years, I am not able to safely handle a full sheet of plywood on a TS anyway. I always cut them down to a manageable size using a circular saw.
-- Joe
View HorizontalMike's profile
HorizontalMike
7747 posts in 2819 days
#2 posted 11-30-2011 04:27 PM
I am with Joe on this, sell them and get what you actually need. Make sure you specify that the buyer pays for shipping, as I would imagine that alone could eat up most of the $$$. Best to find a local buyer.
Good luck!
View Bertha's profile (online now)
Bertha
13505 posts in 2598 days
#3 posted 11-30-2011 04:38 PM
I’d cut them myself.
Alexdi
#4 posted 11-30-2011 09:21 PM
Shipping anywhere would be by freight, which is about $250 for rails this size. It’d have to be a local buyer. There’s an online metal shop that would sell 8’ of rectangular tubing and angle steel for about $170. Another place has 10’ for $350. Neither include shipping, but are probably representative of local supply. If it’s this common, I don’t feel so bad about cutting it.
Joe, I’ve seen some really clever plans for a panel saw based on a circular saw. If I had a smaller shop and was regularly cutting plywood, I’d probably make one and live with a smaller TS arrangement.
View dbray45's profile
dbray45
3310 posts in 2681 days
#5 posted 11-30-2011 09:33 PM
I would cut them and sell the 8’ off-cuts to buy the wood for my next project.
-- David in Damascus, MD
View Loren's profile
9948 posts in 3553 days
#6 posted 11-30-2011 09:34 PM
I don’t think you’ll have luck selling them so you might as well
cut them.
On the other hand, that 13’ rail would make a nice beam for
a shop-built vertical panel saw. I shopped around myself
for beam material for mine and eventually settled on an
extruded aluminum beam because I found the material
at a good price.
That B-fence rail material is just generic rectangular steel
section. You can get a new piece easily enough in whatever
modest length you want.
View 6t5Goat's profile
6t5Goat
71 posts in 2916 days
#7 posted 11-30-2011 09:53 PM
I say cut them.. Its just square tube..
I put 72 inch rails on my saw.. And put the blade right in the middle.. so 36 each side of the blade.. I wish I would have offset them..
I’d sure like to have 48 inches on the right side of the blade…
I’ll get around to it one day..
Alexdi
#8 posted 11-30-2011 10:04 PM
Seems like a consensus. I can deal with a 9’ fence, I think that’s what I’ll do. Not really an overriding concern as the saw is in pieces being painted, but soon enough. Thanks!
