bad vibrations
Forum topic by Chris Carlson posted 11-30-2011 11:37 AM 1407 views 0 times favorited 6 replies Add to Favorites Watch
View Chris Carlson's profile
Chris Carlson
18 posts in 2394 days
11-30-2011 11:37 AM
Topic tags/keywords: tablesaw
I just bought a used 36-670 delta table saw with stamped steel wings. The saw vibrates really bad. I just changed the belt and still no change. I cannot change over to 220 die to the wiring in my garage. Is there anything else I can try.
View bluekingfisher's profile
bluekingfisher
1250 posts in 3004 days
#1 posted 11-30-2011 12:16 PM
Sounds like your motor pulley is out of line with your arbor pulley. It’s a simple fix, just loosen the bolts of the motor holding it onto the support plate and bring it in line with the motor pulley, Use a straight edge for accuracy.
I would also check that all bolts are secure, including the bolts holding the table to the trunion
If it’s not this, check the arbor itself, it may be twisted or a bearing maybe worn. This is the least likely but the one job you least want to tackle if the arbour/bearing needs replacing Good luck.
David
-- No one plans to fail, they just, just fail to plan
View Mickey Cassiba's profile
Mickey Cassiba
312 posts in 3056 days
#2 posted 11-30-2011 01:14 PM
The belt may also have a ‘set’ to it. This occurs when the machine is unused for a while but the belt is left ‘in tension’. A belt replacement could be in your future. I use a harbor freight link belt on my -441, and there is no vibration.
-- One of these hammers oughta fix that...
Chris Carlson
#3 posted 11-30-2011 02:54 PM
Thanks guys I will try that
View Alexdi's profile
Alexdi
21 posts in 2433 days
#4 posted 11-30-2011 10:31 PM
Motor bearings, arbor bearings, broken motor mounting bracket, pulley alignment, belt set, warped pulleys, warped blade… what else? That’s all I can think of.
View knotscott's profile
knotscott
8056 posts in 3400 days
#5 posted 12-01-2011 12:39 AM
To help isolate the source, take the belt off and run the motor, If the vibration persists, it’s the motor shaft, bearings, motor mount, or pulley. If the vibration stops, it’s likely the arbor, arbor pulley, or belt. Check the alignment of both pulleys too. It could also be the blade….have you tried running it without the blade?
Changing to 220v wouldn’t solve a vibration problem.
Chris Carlson
#6 posted 12-01-2011 11:06 PM
Thanks for all of your help. I bought a new blade and the sliced most of the vibrations. I think I still will buy a power twist link belt. I love this saw I can’t wait for the next project.
Chris
