| Forum topic by D11RDozer | posted 541 days ago | 2693 views | 0 times favorited | 16 replies | ![]() |
541 days ago |
Topic tags/keywords: walnut mahogany I’m looking for some help in identifying these two boards I recently acquired. My uncle gave me the wider board and told me it is Mahogany. The other board I bought in a going-out-of-business lot from a custom cabinet maker that told me it was Walnut. I’m having a hard time telling the difference and am wondering how similar the two woods are. To me the one that is supposed to be Mahogany could just as easily be Walnut, though it does seem to be a little more dense. The boards are nice and wide rough cut 8/4 planks. I planed a bit off the face of each board (pics 3 and 4) to see what was below the rough surface, but I still can’t tell the difference. So, I’m posting some pictures here to see what others think I have here.
16 replies so far
#1 posted 541 days ago |
The board on the right of pics looks to be the walnut board. Wetting a small area with water may help tell them apart as well. The walnut should be a little more of a deeper brown, while the mohagany board may have a slighy redder tone. Both boards are very nice, good score. |
#2 posted 540 days ago |
Cut and sniff? -- Optimists are usually disappointed. Pessimists are either right or pleasantly surprised. I tend to be a disappointed pessimist. |
#3 posted 540 days ago |
I’ve never worked with either wood before so I don’t know what the difference in smell would be either. |
#4 posted 540 days ago |
The right is walnut left mahogany, nice boards. what you gonna build? |
#5 posted 540 days ago |
okwoodshop, if that’s the case, both guys were wrong. Seems to me that both are walnut. So far that seems validated since the assumption of two post to this point say the “mahogany” board is walnut. Not sure what to build with these yet. I’m open to suggestions there as well. |
#6 posted 540 days ago |
I believe that the fourth pic is mahogany. It shows the striped effect of the spiral grain that is characteristic of mahogany. The stripes are caused by the angle of the vessel elements (water conducting cells) changing each year so that they reflect the light differently and show the striped effect. I am not sure which board is featured in the fourth pic, but I believe that at least one of the boards must be mahogany. -- Wood-Mizer LT15 |
#7 posted 540 days ago |
The 4th picture is the narrower, lighter one in all the pictures, the one that is supposed to be walnut. |
#8 posted 540 days ago |
Okay, after looking closer I may have to change my mind. As my monitor came over on the mayflower the color is no longer accurate. I still believe the board on the right is walnut but the one on the left may be also but with more sap wood showing.here are a couple pics of walnut and mahogany.The board on the right is mahogany |
#9 posted 539 days ago |
The left is walnut (possibly steamed) and the one on the right is definitely mahogany, probably african mahogany (khaya). -- Brian T. - Exact science is not an exact science |
#10 posted 539 days ago |
Ripthorn – are you referring to the OP’s (D11RDozer) boards or the photo that okwoodshop posted in the thread? Because those are different boards and the difference is quite obvious in okwoodshop’s example. Personally I’m feeling like both boards are walnut…a little cut and sniff from someone who has worked with walnut would confirm. -- Optimists are usually disappointed. Pessimists are either right or pleasantly surprised. I tend to be a disappointed pessimist. |
#11 posted 539 days ago |
In the photo posted by okwoodshop, the left is walnut, the right could be mahogany, but it would be a lesser cut, maybe towards the top of the tree. -- Paul, Tennessee, http://www.tsunamiguitars.com |
#12 posted 538 days ago |
The left is definitely walnut and the one on the right looks like some ribbon mahogany if it is pretty dense it may be something else |
#13 posted 538 days ago |
After looking at the pics again, I also think that they are both walnut. -- Wood-Mizer LT15 |
#14 posted 538 days ago |
I also think they are both walnut. Do the shavings from the small bit you planed smell the same? Despite not having worked with it before, walnut has a distinctly different smell from mahogany. |
#15 posted 538 days ago |
I couldn’t really detect any smell from either. Maybe my sniffer is broken. I did plane a bit more into the larger board and I’m really thinking it’s walnut. I guess in some sense it doesn’t matter so long as whatever I build has a consistent look to the grain and color. Maybe two single board projects. |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15790 |
Hand Tools
2037 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
