Thin (3/8") material glue-ups
Forum topic by JPZ posted 11-29-2011 03:09 PM 1923 views 0 times favorited 10 replies Add to Favorites Watch
View JPZ's profile
JPZ
17 posts in 2502 days
11-29-2011 03:09 PM
Topic tags/keywords: question pine oak joining
Hi all!
I need to glue up about 40 feet of 3/8” thick pine & oak into panels measuring 12”-15”.
I have never just jointed the edges, applied glue and clamped. I have always either used dowels or biscuits, but with this thinner material I am concerned that it is not thick enough to accept a biscuit.
Has anyone had sucess for the long term longevity of glue joints in thinner material?
What can you suggest that works from your experience?
The finished panels will be used for lightweight cabinets.
Thanks!
JPZ
10 replies so far
View crank49's profile
crank49
4032 posts in 2997 days
#1 posted 11-29-2011 03:29 PM
Only done this once.
Used CA glue, wood was red oak.
Worked well, but would get expensive for 40 ft of joints.
Why not use plywood for cabinets?
16275 posts in 4244 days
#2 posted 11-29-2011 04:04 PM
I have glued up 3/8 material many times for making boxes, and I’ve never had a problem. Granted, I’m talking about items that don’t get a lot of stress, but that’s my experience.
View Jim Finn's profile
Jim Finn
2658 posts in 2948 days
#3 posted 11-29-2011 04:16 PM
I also have done this type of glue up for boxes. I use masking tape to hold the two pieces of wood together , turn the assembly over and”hinge” open and apply wood glue. Close up and lightly clamp then remove the tape to allow to dry. The tape helps to keep the woods aligned.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View TheDane's profile
TheDane
5441 posts in 3689 days
#4 posted 11-29-2011 04:21 PM
Jim is right … depending on which glue you use (I have used TiteBond III), the glue joint will likely be stringer than the wood.
In material that thin, I would think you would run the risk of the biscuit swelling so much that it could blow out the face of the boards on either side of the joint.
—Gerry
View grizzman's profile
grizzman
7836 posts in 3329 days
#5 posted 11-29-2011 04:24 PM
there is no problems gluing this type of wood up, you just want to make sure it stays aligned, not only should you cl;amp it all together from the sides, but you should use some culls over and under and clamp it, that will keep it aligned and perfectly flat, put wax paper between the culls and your glue up, that way it doesnt glue itself to the culls ,
just make sure you use enough glue so that you get a proper squeez out…doing this will give you a proper glue up with no problems…good luck, it should all go just fine,
-- GRIZZMAN ...[''''']
View Grandpa's profile
Grandpa
3259 posts in 2701 days
#6 posted 11-29-2011 04:48 PM
Glue ups are glue ups. All the same. The thin stuff you are talking about has many joints so there is room for the wood to slip and get out of alignment but I would use Tite Bond glue or Elmers yellow glue. You might consider doing it in small segments then glue those up into larger segments. This just gives you more control over the joints. Gary is correct. the joints will be stronger than the wood. If you can glue up a wide board then you can glue up a narrow board. any flat surface with long grain will work. Cauls and wax paper will probably be your best friend. Good luck with you project.
View Domer's profile
Domer
252 posts in 3392 days
#7 posted 11-29-2011 05:09 PM
I often glue up 1/4” panels for frame and panel. I use Tightbond III You just have to be careful that they are all aligned. If you have a thickness planer or a drum sander, you can glue them up a little over sized and then either plane or sand them down to the thickness you want.
My furniture where I have used this method are several years old and no problems as yet.
I agree with Grandpa and several others in that if you are making larger panels, you might want to consider making several smaller panels and then gluing them together.
Domer
View MrRon's profile
MrRon
4795 posts in 3269 days
#8 posted 11-29-2011 05:49 PM
Are you gluing pine to oak or pine to pine and oak to oak? Gluing a soft to a hardwood might present a stability problem.
Grandpa
#9 posted 11-29-2011 10:04 PM
I glued red oak to yellow pine and I was a little worried about the expansion rate. It has worked great for 9 or 10 years.
View JPZ's profile
JPZ
#10 posted 11-30-2011 07:05 AM
Thanks to all of you for your replies.
As TheDane pointed out, I too was concerned abou the biscuits swelling and bursting through the top/bottom of the panels.
JimFinn- I like the tape idea and will use it.
Grizzman – good idea. I do have some wooden clamps that exert pressure on all 4 planes that I even forgot I had.Thanks for reminding me.
Grandpa – I like your idea and will be breaking the job into smaller segments
Domer – Titebond III it is. I’ve used the regular Titebond but I’m almost out. Unfortunately my planner only goes to 12” wide, otherwise I would definetly go oversized and plane down after glue up. If I’m going to do a lot of this work I definetly will invest in a thickness sander. That’s one machine I would give a go at by building it myself. I’m sure there loads of info on this site for ideas and plans.
MrRon – Never thought about the possible problems of mixing woods, but appreciate you pointing that out.
