flooring underlayment
Forum topic by hockeydad2 posted 11-28-2011 05:00 PM 939 views 0 times favorited 6 replies Add to Favorites Watch
View hockeydad2's profile
hockeydad2
1 post in 2340 days
11-28-2011 05:00 PM
Have been wondering about the moisture barrier for a basement wood floor. Recommendation is that a plastic vapor barrier be placed under the flooring. I am wondering if mylar space blankets wood work and if so would the radiant (reflective side go up toward the interior of the space or down toward the ground. Any comments?
View Jeff's profile
Jeff
429 posts in 3163 days
#1 posted 11-28-2011 05:15 PM
Probably get more answers, quicker by posting to the Home Refurbers site below.
View NBeener's profile
NBeener
4816 posts in 3142 days
#2 posted 11-28-2011 05:40 PM
No expert, here, but … my gut tells me that … if it works … don’t fix it:
http://www.homedepot.com/buy/flooring/flooring-tools-accessories/2-5-ft-x-40-ft-moisture-barrier-6mil-polyethylene-film-91318.html
Meaning … there’s a low-cost, time-tested product type that’s “always” used in this application. I wouldn’t be in a hurry to get creative, on this one.
Good luck !
-- -- Neil
View Sawkerf's profile
Sawkerf
1730 posts in 3037 days
#3 posted 11-28-2011 06:01 PM
Why would you want to use space blankets? They gotta be way more expensive than the plastic vapor barrier recommended by the flooring manufacturer.
117063 posts in 3546 days
#4 posted 11-28-2011 06:10 PM
All you need is 6mil vapor barrier(black plastic) on the ground beneath the floor. If you want to get really crazy you can use pressure treated Plywood, a giant overkill.
View Grandpa's profile
Grandpa
3259 posts in 2644 days
#5 posted 11-28-2011 06:11 PM
I think he is wanted to reflect the heat back into the room with a space blanket. They are good …BUT…. at 11 feet the earth is a constant temperature meaning it does not fluctuate with the seasons. I don’t think you would gain much savings at that depth and I would have to assume you would be close to that depth with a basement floor.
View crank49's profile
crank49
4030 posts in 2939 days
#6 posted 11-29-2011 01:49 AM
Yes, but that constant temperature is ~55 degrees. If it’s 0 degrees outside you might find the 55 degree earth actually reduces your heat load. I don’t heat or cool my basement shop and it’s pretty comfy just from the heated or cooled space above.
