Running hardwood thru planer?
Forum topic by ChesapeakeBob posted 11-26-2011 11:36 PM 5599 views 2 times favorited 28 replies Add to Favorites Watch
View ChesapeakeBob's profile
ChesapeakeBob
366 posts in 3477 days
11-26-2011 11:36 PM
Topic tags/keywords: planer
Many years ago, my high school shop teacher told me to apply a little water before running hardwood like oak through the planer. I thought of this today while I was planing hardwood cutting boards. Does anyone use my old shop teacher’s “trick?” Any real advantages?
-- Chesapeake Bob, Southern Maryland
28 replies so far
View bent's profile
bent
311 posts in 3663 days
#1 posted 11-26-2011 11:41 PM
maybe to raise the grain on the board, or cut down on dust?
117090 posts in 3571 days
#2 posted 11-26-2011 11:44 PM
It’s a good trick to use on highly figured wood to help prevent tear out.
View Bill White's profile
Bill White
4928 posts in 3954 days
#3 posted 11-26-2011 11:53 PM
It’ll work. Just allow the wood to dry before ya run it. Don’t want to run wet wood thru the ‘chine. That’ll make a mess.
It raises the grain, but then cuts off what is raised. Think that you’ll have to do it again after planing/staining before sanding the final surface? Yep.
Bill
-- bill@magraphics.us
#4 posted 11-26-2011 11:58 PM
Hate to disagree but the wet wood is what keeps the wood from tearing out.
View NiteWalker's profile
NiteWalker
2737 posts in 2571 days
#5 posted 11-27-2011 12:36 AM
Yep, that’s what I learned as well Jim.
View Charles Maxwell's profile
Charles Maxwell
1099 posts in 3801 days
#6 posted 11-27-2011 12:42 AM
I never knew! Thanks. Will test on my planer with my next piece of figured wood.
-- Max the "night janitor" at www.hardwoodclocks.com
View usnret's profile
usnret
184 posts in 2502 days
#7 posted 11-27-2011 12:57 AM
Like Jim said for figured wood wet it before you plane it. You dont soak the wood just use a damp cloth on the wood to get the surface moist before you plane it. Works like a charm, I have done this and no problems with my portable planer.
-- Chief Petty Officer USN(RET) 1991-2011
View tenontim's profile
tenontim
2131 posts in 3738 days
#8 posted 11-27-2011 12:59 AM
I used this method a lot when planing ash, with all of it’s crazy grain directions. Since I changed over to the Shelix head on my planer, I don’t have to worry about it. And yes, you don’t want to let the board dry out, or it won’t do any good.
#9 posted 11-27-2011 01:00 AM
Another good point is since I’ve owned a spiral head planner I haven’t found it necessary to wet figured wood to stop tear out.
Opps looks like Tim and I were posting the same time ,I didn’t mean to repeat his comment..
View MNWOODWORKER's profile
MNWOODWORKER
105 posts in 3579 days
#10 posted 11-27-2011 07:55 AM
I have done it with pretty good results on figured wood, but since getting a drum sander figured wood never meets my planer.
View childress's profile
childress
841 posts in 3536 days
#11 posted 11-27-2011 08:28 AM
used that technique today with some hard rock maple….works great
-- Childress Woodworks
View fussy's profile
fussy
980 posts in 3045 days
#12 posted 11-27-2011 10:53 AM
I’m planing pommelle sapele tonight with a DW 735, and even with fresh blades and a light cut, it looked like
it had been hit with shotgun pellets. I remembered this trick, and as that Navy guy ( thanks for your service, and do all the boats still have those little round windows?) and Jim said, don’t soak it. Moisten with a cloth, run at an angle, and Most of the tear-out will be gone.
Steve
View Knothead62's profile
Knothead62
2584 posts in 2955 days
#13 posted 11-27-2011 09:27 PM
“do all the boats still have those little round windows?) ”
Never saw one on a submarine. Interesting thread as I have some pecan to plane this winter.
View tamboti's profile
tamboti
207 posts in 3136 days
#14 posted 11-28-2011 01:31 PM
Hi I use parrafine as it is inert and dries quite quickly does not affect the wood in any way, learnt this from some full time carvers who were carving hard wood chair legs. Regards Roger in RSA
-- Africa is not for sissies
View toddbeaulieu's profile
toddbeaulieu
814 posts in 2998 days
#15 posted 11-12-2012 01:19 AM
I just love reading about how dumb I am.
I searched “planing wet wood” to see if that’s why I had such a hard time tonight with simple 2x material. I tried planing it both ways when I saw tearout and still got terrible results on most the boards.
My theory: maybe they had too much moisture? Apparently, that ain’t the case.
So now my theory is dull blades? Which is irritating since they’re new … except I ran a bunch of reclaimed maple treads through them (with finish). I think that must have killed them.
showing 1 through 15 of 28 replies
