I need help with a design issue
Forum topic by Alongiron posted 11-25-2011 06:48 PM 1468 views 1 time favorited 21 replies Add to Favorites Watch
View Alongiron's profile
Alongiron
643 posts in 2566 days
11-25-2011 06:48 PM
I am working on a Christmas present for my parents and I need your help with how I should make the top for my Arts and Craft Pedestal. I have attached a few pictures of a prototype that I have made out of particle board (the finish product will be made from QSWO). The legs are 36” tall and the top options are 15” wide. One has a round top, One has a square top that is square to the legs, the other is a square top that is skewed 45 degrees to the legs. I would really like any thoughts that you may have. Thanks for your votes and thoughts. I think this is really going to be a nice project when it is complete. I will post the completed project.
Option #1
Option #2
Option #3
-- Measure twice and cut once.....sneak up on it! Steve Lien
21 replies so far
View MrRon's profile
MrRon
4564 posts in 3116 days
#1 posted 11-25-2011 07:36 PM
I like the skewed 45° to the legs (middle picture). If you could get a piece of solid surface material (Corian), it would look great for a top; otherwise a round top covered with a laminate.
Definitely, the middle picture. I like it because the raw ends of the legs at the top don’t show. If you go with QSWO for the top, I would think a Roman ogee curved edge would look good.
View Peter Oxley's profile
Peter Oxley
1426 posts in 3748 days
#2 posted 11-25-2011 07:41 PM
That’s an attractive design! I like the round top with the curvy legs. I would be tempted to create a cut-out in the legs to emphasize the curve and make the legs look a little lighter. Something a little like this:
Click for details
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
View sras's profile
sras
4687 posts in 3002 days
#3 posted 11-25-2011 07:42 PM
For me, the curves of the legs suggest the round top. maybe just a bit larger diameter might balance it out (like an inch or so).
View Neight's profile
Neight
112 posts in 2266 days
#4 posted 11-25-2011 07:54 PM
I agree with sras, I like the round top, but it looks like it wants to be bigger. Not much, but a little bigger would help balance the curves to each other and the hight of the piece
very nice design though, look forward to seeing the finished product!
-- Work consists of whatever a body is OBLIGED to do, and Play consists of whatever a body is not obliged to do. -Mark Twain
View Jim Jakosh's profile
Jim Jakosh
19957 posts in 2978 days
#5 posted 11-25-2011 09:13 PM
I personally like the round top to go with the curved legs. The top could be maybe 2” larger in diameter and the tops ends of the leg could be curved up using a French curve to get a sweep to them. I thin the blunt ends of the legs takes away from it with either top.
If you do go with a square top, you could consider an apron around the top ends of the legs.
My 2 cents worth…........Jim
View pintodeluxe's profile
pintodeluxe
5544 posts in 2686 days
#6 posted 11-25-2011 09:29 PM
Round top, but bigger top. Add 3 inches to the diameter and you’ll have it just right. What about some cutouts in the legs to reinforce the A&C theme?
View Don Newton's profile
Don Newton
714 posts in 3492 days
#7 posted 11-25-2011 09:48 PM
Round top….definately the round top.
-- Don, Pittsburgh
View willie's profile
willie
533 posts in 2327 days
#8 posted 11-26-2011 03:34 AM
I like the round top but you might also consider an oval shaped top.
-- Every day above ground is a good day!!!
View Grandpa's profile
Grandpa
3259 posts in 2548 days
#9 posted 11-26-2011 06:27 AM
it is all in the taste of the person but I also prefer the round top. The problem with your first photo is the top is barely as large as the leg. if you took the major section of the legs and drew a circle that diameter then the top should be a couple of inches larger than that diameter.
View rance's profile
rance
4255 posts in 3033 days
#10 posted 11-26-2011 06:43 AM
I know it doesn’t help you much but they all three look good. Each one has its merits. I can’t see many drawbacks with any of them.
View ShaneA's profile
ShaneA
6879 posts in 2471 days
#11 posted 11-26-2011 06:48 AM
+1 on the slightly larger round top.
View cathyb's profile
cathyb
768 posts in 3117 days
#12 posted 11-26-2011 06:52 AM
I agree with Rance. Since they all look good, use a another criterion to make the final decision. Where will it most
likely be placed in the room? Would the shape of the top conflict or complement the existing furniture? What will be placed on top of the table? Is it a lamp? Does that lamp have a square or round base…...you see where I’m going, don’t you? If you just want a tally, I like the round top better, but maybe 18” or 20” instead of 15”, since the base could certainly justify that size top.
Good luck…...
-- cathyb, Hawaii, www.cathyswoodworking.com
Alongiron
#13 posted 11-26-2011 04:28 PM
So many great comments….So many great ideas…at the widest part of the base it measures 16” and at the top of the base it measures 13”, so here is a top that has a 16” diameter top on it and the wings have been curved as well. I have decided on that top. One more question….Pete asked that maybe I consider a cut out on the legs…So I have drawn in a 2” stile and Rail design on the second picture..so Solid legs or cut out legs?..remember that this project will be made from QSWO
116807 posts in 3450 days
#14 posted 11-28-2011 03:27 AM
I think if you cut out some the inner legs it would help with it’s vertical flow , I would not take out as much as you have drawn out maybe only about 50% of what you have drawn using the same shape.
pintodeluxe
#15 posted 11-28-2011 03:35 AM
I like the changes you made, it looks nice.
