Assembly bench
Forum topic by Al Killian posted 05-03-2008 01:41 AM 854 views 0 times favorited 3 replies Add to Favorites Watch
View Al Killian's profile
Al Killian
273 posts in 3777 days
05-03-2008 01:41 AM
Topic tags/keywords: question
I am thinking of using plwood to make some hollow legs for the table. Anyone see a reason way it would not work? The legs will be about 3” square. The board would be miterd to hide the edge of the ply and joind with biscuits. From there I plan on mounting the legs on the inside of a skirt/apron and set a torsion box on top of it.
-- Owner of custom millwork shop
3 replies so far
View GaryK's profile
GaryK
10262 posts in 4012 days
#1 posted 05-03-2008 02:30 AM
No reason except the sharp corners. You could run some angle molding along the to cover them though.
Or you can cut about a 1/4” to 1/2” of the sharp bevels off and glue up some solid wood in their place.
That way you could round off the corners.
35125 posts in 4424 days
#2 posted 05-03-2008 10:28 PM
I think I’d go with the solid edges to allow for softening the edges.
Al Killian
#3 posted 05-04-2008 12:19 AM
I guess then I will use up some of the aspen that has been air drying for the last year. Thanks again for the help.
