Mortise and Tenon glue up
Forum topic by woodjunkie posted 11-24-2011 02:06 PM 2111 views 0 times favorited 7 replies Add to Favorites Watch
View woodjunkie's profile
woodjunkie
35 posts in 2631 days
11-24-2011 02:06 PM
Topic tags/keywords: question oak clamp arts and crafts
I am making a Mission Bed. This is my first mortise and tenon build. It is a Queen size and both the headboard and foot board have 29 spindles each. I have dry fitted it and all is well. My question is what type of glue should I use that does not set up to fast so that I have time to assemble and get is squared and clamped.
-- He: Can I get the plans for that? Me: Plans???
7 replies so far
View chrisstef's profile
chrisstef
17299 posts in 2969 days
#1 posted 11-24-2011 03:15 PM
Titebond II makes a glue with an extended open time or you could use hide glue which doesnt require any clamping. TB has a hide glue out there in a brown bottle. There is probably a way to thin the glue as well, ive read using water will slow down the cure rate. I think id go with the hide glue or extended TB II.
404 - Not Found
2544 posts in 2932 days
#2 posted 11-24-2011 04:20 PM
I wouldn’t even attempt to thin the glue. Titebond II extend.
product details here, you may have to search online for it
http://www.rutlands.co.uk/finishes-glues-&-materials/glues/glue---pva/4134/ii-extend-wood-glue---16-oz
View Byron's profile
Byron
92 posts in 2343 days
#3 posted 11-26-2011 07:52 AM
If you need more time or cant find titebond extend epoxy will give you much more open time as well, epoxy wont make the joints expand as you glue up either
-- Byron Conn, Woodworking/Furniture Design at Rochester Institute of Technology, http://byronconn.com
woodjunkie
#4 posted 11-28-2011 05:20 PM
I have found the Titebond Extend. Thanks for all the info guys!
View tbone's profile
tbone
275 posts in 3647 days
#5 posted 11-29-2011 05:06 PM
You’ve got plenty of good suggestions already, but if you can find plastic resin glue—DAP Weldwood—you’ll have plenty of open-pot time for that extensive glue-up.
Also, if those spindles fit fairly snug, I’m not sure it would be necessary to apply glue to all of them.
Let us know how the Titebond Extend works out for you.
-- Kinky Friedman: "The first thing I'll do if I'm elected is demand a recount."
woodjunkie
#6 posted 11-30-2011 03:21 PM
You have a good point Tbone. The tenon fit very tightly into the Mortise. I am thinking maybe they do not need to be glued as they really do not contribute to the strength of the bed. Thanks for getting me focused.
View Sgt374's profile
Sgt374
36 posts in 2557 days
#7 posted 11-30-2011 03:52 PM
Without a doubt the best glue for that particular job would be Old Brown Glue by Patrick Edwards. It is a liquid hide glue with a long working time and completely reversible. It also won’t show up like other glues when stained and finished. I really recommend checking out his web site.
