Proper wood for kids workstation
Forum topic by newby1790 posted 11-24-2011 10:54 AM 1148 views 0 times favorited 6 replies Add to Favorites Watch
View newby1790's profile
newby1790
4 posts in 2285 days
11-24-2011 10:54 AM
I’m getting ready to build a counter-height workstation for my kids but I’m having trouble deciding on the proper type of wood for this project. I’m not the most skilled woodworker, but I do have the basic skills. I was thinking of using either birch 3/4” plywood or MDF since I will be painting it. Any thoughts?
Here’s a similar style of what I’m building that i found on the web.
http://www.mylearningtower.com/gallery/My-Learning-Tower/Black_Dark_Cherry_White_TowersNolan_049
Thanks for your help.
newby1790
#1 posted 11-26-2011 06:51 PM
which type of wood would you recommend? do you think the 3/4 birch ply will be ok when i route the edges?
View Mahoganus's profile
Mahoganus
46 posts in 2669 days
#2 posted 11-26-2011 07:00 PM
If money is no object I would use solid white oak.
-- Chuck W
View Bill White's profile (online now)
Bill White
4862 posts in 3870 days
#3 posted 11-26-2011 07:06 PM
Plywood edges will show the laminations. MDF will paint and route well, but it won’t be a resistant to breaking as ply iof you have any long, narrow spans without support. There is a much more dense MDF product for exterior use (Extira brand) that might do the job. It is heavy.
Bill
-- bill@magraphics.us
newby1790
#4 posted 11-26-2011 08:53 PM
i’m not too worried about the lamination layers showing if i use plywood. While I want to it be a quality piece, it will be for my kids, who will certainly grow out of it in a few years. i figure a nice cabinet-grade plywood would be sufficient. The only part I’m concerned about is the holding power of screws into the end of the plywood.
newby1790
#5 posted 11-26-2011 09:13 PM
View Sawdust4Blood's profile
Sawdust4Blood
397 posts in 2931 days
#6 posted 11-26-2011 09:17 PM
Screws (if you use the right screws) should have no problem holding in the end of quality plywood … at least better than MDF. However, the best quality plywood can be expensive in its own right. For kids furniture, I would recommend birch ply and poplar….it’s inexpensive but works well. The only issue with poplar is that it doesn’t stain well, so you are better off finishing with a dye instead of a stain. I think that combination will let you build a quality piece that will hold up to the kids use without breaking the bank.
-- Greg, Severn MD
