Anyone here ever make a lathe?
Forum topic by Marcel T posted 67 days ago 449 views 0 times favorited 25 replies Add to Favorites
View Marcel T's profile
Marcel T
110 posts in 117 days
67 days ago
Hey,
I’m thinking abut building a lathe to turn pens. Has anybody ever tried something like this?
Thanks,
Marcel
View trifern's profile
trifern
1920 posts in 158 days
67 days ago
Not me, but good luck.
-- Depend on the rabbit's foot if you will, but remember it didn't work for the rabbit.
Marcel T
67 days ago
Thanks Trifern :)
View jjohn's profile
jjohn
397 posts in 104 days
67 days ago
I did make a very small lathe using a regular drill. Mounted the drill up side down in a wooden holster. (Had to design the holster to fit the drill). Clamped the holster on a 1×6 about 1 ft. long. drove a small nail on the opposing mounted wooded chuck. (The wood spun in the nail).
Don’t know if I explained that well enough to be any help. It did work well enough to lathe 4 legs for a nick/knack table.
necessity is the Mother of invention.
-- JJohn
teenagewoodworker
1689 posts in 159 days
67 days ago
i did and i have a small motor that i use with the tail stock as a bolt that i ground the tip into well i tip. i just cant figure a good spur yet.
Marcel T
66 days ago
Thanks guys!
I have a question about pen mandrels…are they just a piece of metal rod, with threads at the end and a nut? I don’t see why that costs $20+shipping. Ok, so you get a Morse Taper, but I don’t need one. $15 for a drill mount?
11555 posts in 791 days
66 days ago
Yes a metal rod. It has a jam nut to hold all of the pen pieces tight so you can turn them but should not be a problem to make one. Getting the correct size might be a problem. You will want it to fit tight inside the pen blank. Probably metric size rod.
View moonroc's profile
moonroc
38 posts in 79 days
66 days ago
There is a easy way to build one just by adding an adaptor to a drill press. You can find it here http://www.pennstateind.com/store/dplathe.html at around $20.00 I have not used one but maybe someone esle in the forum may have. Good Luck
-- Richard http://www.LearnFineCrafts.com
Marcel T
66 days ago
Allrighty Karson, thanks. That helps a lot!
Thanks for the suggestion moonroc, but I do not have a drill press.
View SteveKorz's profile
SteveKorz
616 posts in 105 days
66 days ago
I started to build a full size lathe a year or so ago. I got the idea from shopnotes. I finished the body and had to quit to get caught up on other things. To be honest, I forgot all about it until you brought up this thread. It didn’t look too hard to make in the shopnotes mag.
-- As iron sharpens iron, so one man sharpens another. (Proverbs 27:17)
Marcel T
65 days ago
Good luck with that Steve, a full size lathe might be a pain to make.
3852 posts in 242 days
64 days ago
Yes for turning billiard table legs but it was a bit risky. I was just a power drill chuck with belt drive on a washing machine motor. nothing compared to a modern lathe but for pens you could use anything. you don’t need a large lathe but you need to control the main enemy thats vibration. An old drill press could have a lot of the components you need. But I would look out for a second hand lathe, there are bargains around.
View TheDovetailJoint's profile
TheDovetailJoint
7 posts in 65 days
64 days ago
Yes, I made two over one weekend when I had a one-time need during a turning class I was teaching. I believe I still have one of them in my garage and will post a pic if I can dig it up.
I used a 5/8” steel rod in bearing blocks for the headstock so I could use Shopsmith lathe accessories, which were easy to obtain at the time.
-- http://shopsmith-tool-hunter.blogspot.com/
View Mark Shymanski's profile
Mark Shymanski
240 posts in 103 days
64 days ago
I’ve been looking around for the bits needed to convert my King DP into a lathe, but the biggest morris taper I’ve seen used in lathes is 2 and my DP has a MT4. Maybe there are stepping adapters? to use the more readily available MT2 lathe parts?
-- cough...cough....next big purchase is wood for the next project, Mark
Marcel T
63 days ago
Billard table lags…wow! If I had a drillpress, I’d have this whole pen thing made! I’ll keep an eye out for lathes, but I really want to make the lathe myself, I really enjoy making things, figuring out their weaknesses and keep on revising.
A picture would be fantastic, TDJ!
I’m sure there is a stepper or something of the sort SOMEWHERE one the great, vast internet Mark.
Thank you all! :)
View tjocpa's profile
tjocpa
9 posts in 88 days
62 days ago
ShopNotes number 73 has plans for a shop-built mini-lathe and accessories.
-- Tom O'Neil, Celtic Saw Guy
View DannyBoy's profile
DannyBoy
200 posts in 256 days
62 days ago
If you look around, there are a few plans out there for a treadle lathe that uses a foot treadle and a large flywheel for the motion. They are almost entirely made of wood, but because of that they tend to be big and heavy.
~Danny Boy
-- Happy Ripping!!!
View matter's profile
matter
170 posts in 160 days
62 days ago
Do a search on FWW, there was a “beer box lathe” design article- possibly as early as late 70’s or early 80’s. I know a guy who built it, and enjoyed it for quite a few years.
Good luck.
Matt
-- The only easy wood project is a fire
Marcel T
61 days ago
Where could I get Shopnotes #73?
Thanks Danny, but thats not really what I am looking for.
Whats FWW?
tjocpa
9 posts in 88 days
61 days ago
This is the cover of the ShopNotes #73 with the shop built mini-lathe. Is this what you had in mind? I remember it because I thought I might build one some day. Haven’t yet. The ShopNotes website is: www.shopnotes.com They may be able to provide the issue.
ShopNotes #73
Marcel T
60 days ago
It looks a bit bigger than I was thinking about, but it does look good! Thanks so much! :)
TheDovetailJoint
7 posts in 65 days
58 days ago
Marcel T,
Here’s one of the lathes I made one weekend. They worked very well. They were clamped to a bench, with the motor mounted on a board and clamped to the back edge of the bench. The belt was ridiculously long because it’s what I had on hand. There are more details and pic on my blog.
Shop-made wooden wood turning lathe
matter
58 days ago
FWW is Fine Woodworking magazine.
Marcel T
56 days ago
Wow TDJ, that looks awesome! Thanks for the picture :)
Thanks Matter.
View Woodshopfreak's profile
Woodshopfreak
315 posts in 133 days
53 days ago
NO but it doesn’t look that hard to make. Just need a motor and some plywood and you will be well on your way to make one.
-- Tyler, Illinois
Marcel T
53 days ago
Well I gotta dremel and some offcuts, this should be interesting :) Thanks Tyler :)
(I really do overuse those smileys)
Bookmark And Share This Page
