Veneer tape
Forum topic by Sgt374 posted 11-23-2011 09:21 PM 1168 views 0 times favorited 6 replies Add to Favorites Watch
View Sgt374's profile
Sgt374
36 posts in 2716 days
11-23-2011 09:21 PM
I have some old veneer tape that won’t stick anymore. The role is a couple years old
And used to work fine. It has been stored in an unheated garage where it may have froze at one time.
Does veneer tape go bad? And why?
View Lee Barker's profile
Lee Barker
2170 posts in 2972 days
#1 posted 11-24-2011 01:02 AM
There is evidently some critical solvent that escapes the glue over time. I learned the hard way, and it seem such an unlikely characteristic of a hot melt product that I am not sure one could learn any other way.
Kindly,
View doncutlip's profile
doncutlip
2832 posts in 3678 days
#2 posted 11-24-2011 01:06 AM
I don’t know if it goes bad. I had some in my basement for 3 years and just pulled it out last month and it worked fine. It might be very low humidity during cold times that dried it out.
-- Don, Royersford, PA
Lee Barker
#3 posted 11-26-2011 03:01 AM
Thanks Cr1—I was thinking of sticks of hotmelt. Do they age?
Kindly,
Lee Barker
#4 posted 11-26-2011 07:07 AM
Fascinating….keep writing!
Sgt374
#5 posted 11-26-2011 03:41 PM
Thanks for all of your input
View MarcusM's profile
MarcusM
57 posts in 3102 days
#6 posted 11-26-2011 05:22 PM
Lee, I can’t say definitively that hot melt sticks don’t age but if they do, they do so more gracefully than you or I. I have some glue sticks that are easily 35 years old that I use on occasion and have not noticed any degradation in their performance.
I don’t think the adhesive on the iron-on edging/venneer is the same formula as the glue sticks, and have seen it go “bad” (at least partially) over time. The upside is that, that adhesive is fully compatible with regular contact cement.
Regards, Mark
-- Tilbilly Mark
