Curious minds need to know
Forum topic by Moron posted 11-22-2011 07:25 AM 1575 views 0 times favorited 14 replies Add to Favorites Watch
View Moron's profile
Moron
5032 posts in 3892 days
11-22-2011 07:25 AM
why is at some job sites, tools you plug into an electrical wall outlet
the tools don’t work. The master of frustration is a shitty electrician.
is it because the electrician doesn’t know his shit ? and cheated on the gauge of the wire ?
or do I blame my tools ?
14 replies so far
View Bill1225's profile
Bill1225
125 posts in 2398 days
#1 posted 11-22-2011 07:42 AM
we run our own homeruns right to the panel then feed to the tools with a 10 then no one can complain
Moron
#2 posted 11-22-2011 07:51 AM
I hate revisiting bad math
Moron
#3 posted 11-22-2011 05:52 PM
I should also mention that I have met far more “good” trades then “bad”
View klassenl's profile
klassenl
185 posts in 2657 days
#4 posted 11-22-2011 09:18 PM
This sounds like a rant more than a question….....but….......remember, just because there is a plug in a wall somewhere on some job site, it doesn’t mean that it’s turned on.
-- When questioned about using glue on a garbage bin I responded, "Wood working is about good technique and lots of glue........I have the glue part down."
View Bill White's profile
Bill White
4930 posts in 3959 days
#5 posted 11-22-2011 09:27 PM
What do ya mean by “don’t work”? They don’t turn on? Circuit breakers flippin’?
Bill
-- bill@magraphics.us
Moron
#6 posted 11-22-2011 09:29 PM
I mean that when I plug my saw in, my compressor or anything that draws up to 13 amps……….it trips the breaker and there is nothing else plugged into the series of outlets
Go to another job site………same amp breaker, never trips the breaker
why?
117091 posts in 3575 days
#7 posted 11-23-2011 12:46 AM
One more. your plugging in one tool and trying another one that has a dead battery :))
View JJohnston's profile
JJohnston
1622 posts in 3290 days
#8 posted 11-23-2011 03:16 AM
Same reason there was a truck in my neighborhood on the way home tonight, where there’s only one way in, backed out of its driveway, perpendicular into the street, exactly as long as the street is wide, that had died and wouldn’t start. To wit:
TO MAKE YOU ASK WHY!!
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View Irv2012's profile
Irv2012
3 posts in 2375 days
#9 posted 11-23-2011 10:21 AM
How old is the circuit breaker.. if wire size is correct on both ends. Than I’d suspect the circuit breaker is faulty
Moron
#10 posted 11-23-2011 03:52 PM
funny comments and thank you
all sites are brand new, new building, new electrical
View helluvawreck's profile
helluvawreck
31082 posts in 2865 days
#11 posted 11-23-2011 04:29 PM
It’s another indication that Murphy’s law is always at work – just like law of gravity – if it can go wrong it will go wrong -
sooner or later – probably sooner. ;-|
404 - Not Found
2544 posts in 2968 days
#12 posted 11-23-2011 08:07 PM
Ring main vs spur socket. Don’t ask me what the difference is because I’m not an electrician. But I know my planer/thicknesser eats fuses when its plugged into one particular socket in my workshop and works fine on the others. My 110v transformer often trips the breaker.
View brimus's profile
brimus
#13 posted 11-23-2011 11:06 PM
The make of the breaker can have a cause, SquareD or Cutler Hammer have a better action tripping where it is supposed to and ones like Sylvania will trip way past the correct rating (20 amp circuit should trip at 16 amps continuous load – 80% load).
Any loose connection or damage to the line can cause an increase in amperage draw added to the tools draw.
As a tool gets older it will slowly increase amperage draw from degradation also what load is used on it like a saw can increase the draw past the rating, do not assume the draw on a tool is what is stated on the label.
Job site connections are required to be GFI, some tools will start to bleed to ground as they wear and that will cause GFI to trip, along with additional moisture cam cause them to trip. Some improper electricians remove the GFI after in inspection for reduced tripping but is not supposed to be done.
Most of the time that these occur the people are complaining about it working properly (tripping the circuit) and think the improper operation (does not trip the circuit) as the correct situation.
-- Brian
Moron
#14 posted 11-24-2011 05:59 PM
Good to know, thanks Brian
