Primer
Forum topic by themitrejoint posted 11-22-2011 02:37 AM 1075 views 0 times favorited 9 replies Add to Favorites Watch
View themitrejoint's profile
themitrejoint
18 posts in 2632 days
11-22-2011 02:37 AM
Topic tags/keywords: primer finishing spraying
I need help!
I spray (HVLP) a lot of water based paint. Through trial and error I have finally come up with the right match of viscosity and nozzel to achieve a good final result. My problem is primer. To get it to flow out, I spray it liberally. According to the manufacturer, if put on heavy, it can take a week or more to dry sufficiently for sanding. I am using a high grade sandpaper that loads up almost immediately. I have waited 24 hours and it still loads the sandpaper.
Can anyone recomend a good water based fast drying primer.
-- Frank, Hagerstown, Maryland
9 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 3065 days
#1 posted 11-22-2011 02:46 AM
I just finished shooting a water based primer (Zissner 1-2-3) on some raised panel doors and drawer fronts. I shoot just enough to get full coverage, then stop. By the time I finished cleaning the gun, everything was dry to the touch. Tomorrow, I’ll hit it with a fine grit sanding sponge and call it good. Only a few spots will even need that.
Primer always loads the sandpaper if you put it on too thick. You only need enough to cover the wood and give a good base for the paint.
themitrejoint
#2 posted 11-22-2011 02:53 AM
Thanks. If I use your method I will save money both on sandpaper and primer.
Which gun are you using?
Sawkerf
#3 posted 11-22-2011 06:08 PM
I use a Husky Pro conversion gun. I got it a few months ago and am still working on the best settings to get things just right. I’m pretty happy with it, so far.
View Bill White's profile
Bill White
4929 posts in 3957 days
#4 posted 11-23-2011 07:24 PM
You didn’t say what primer you used.
Bill
-- bill@magraphics.us
themitrejoint
#5 posted 11-23-2011 10:50 PM
I am using “Zinsser Bulls Eye Water-Base Primer & Sealer”. I tried (“Sawkerf’s suggestion) spraying a very light coat and that worked much better. I was able to sand satisfactorily in 2 hours.
themitrejoint
#6 posted 11-23-2011 10:51 PM
Thanks Sawkerf, your method worked.
themitrejoint
#7 posted 11-23-2011 10:59 PM
Another question – anybody know where can I buy “trim screws”? I can only find 1 5/8” and 2 1/4” When I build cabinets with double sides, I fasten the sides thru the shelf pin holes while the glue dries. I am looking for trim screws from 1 1/2” thru 3” (1 1/2”, 2”, 2 1/2” & 3”). The only place I found with all the sizes only sells in bulk lots of 1000 or more.
View Bluepine38's profile
Bluepine38
3379 posts in 3082 days
#8 posted 11-24-2011 01:06 AM
Have you looked at McFeely’s? I have several sources here in Missoula, Mt, but it is a little ways to drive.
404 - Not Found
2544 posts in 2966 days
#9 posted 11-24-2011 02:19 AM
I use the waterborne primer from Becker Acroma. It dries fast (as long as you haven’t flooded it) and won’t clog the abrasive. If you want it to flow better without thinning, put the pot in bucket of hot water for 30mins before spraying.
