Milling wide boards with 6" jointer
Forum topic by Michael J posted 11-21-2011 09:26 AM 2884 views 0 times favorited 16 replies Add to Favorites Watch
View Michael J's profile
Michael J
103 posts in 3208 days
11-21-2011 09:26 AM
Topic tags/keywords: wide boards jointing
Hey All,
I just wanted to pass along a tip I learned awhile back from one of the Wood Whisperer videos that worked really well for me when trying to mill some 9” wide bloodwood that was cupped on one side. It worked really well for me.
Here’s what I did:
1) Remove the jointer guard.
2) Run 9” wide stock through jointer as normal with the cup side down.
3) After about 4-5 light passes, with 6” of the stock jointed, use double sided tape and attach the board to 1/2” ply to the jointed part of the board.
4) Run the board through the planer with as many passes needed to flatten.
5) After the board is flattened remove from plywood and plane as normal.
This method worked really great for me. My apologies if this is a well known technique and I’m being redundant. I’ve only seen the planer sled technique mentioned for flattening wider boards than your jointer.
-- Mike Minneapolis, MN
16 replies so far
View Gene Howe's profile
Gene Howe
10479 posts in 3429 days
#1 posted 11-21-2011 02:17 PM
If I understand, there will be 3” of the width unsupported?
It didn’t tip when you ran it through the planer?
View tenontim's profile
tenontim
2131 posts in 3745 days
#2 posted 11-21-2011 02:58 PM
I use this method with a 1/4” piece of ply, with a stop block on the end to keep the board from slipping off of the ply, instead of tape. The board won’t tip, Gene. I don’t think I’ve done any wider than 9- 9.5”, so it may tip if you get close to equal sizes on and off the plywood.
Gene Howe
#3 posted 11-21-2011 07:32 PM
Thanks Tim.
I’m gonna try it.
Michael J
#4 posted 11-21-2011 07:37 PM
Gene,
You are correct. About 3” were unsupported. It was more than stable when I ran it through the planer. I think a good rule of thumb seems to be about 2/3’s your jointer width from what I recall from the video and my own experience. Give it a try. I was surprised that it worked so easily.
View Adam's profile
Adam
46 posts in 3154 days
#5 posted 11-21-2011 10:53 PM
Mike,
Do you have a link to the video, I’m having a hard time wrapping my head around this.
Adam
View slimjim145's profile
slimjim145
10 posts in 2680 days
#6 posted 11-22-2011 04:14 PM
yes I second that Adam, a video would be nice!
View PurpLev's profile
PurpLev
8535 posts in 3649 days
#7 posted 11-22-2011 04:44 PM
+1 vote here. that’s a good streamlined technique to use on wider boards.
Michael J
#8 posted 11-23-2011 09:40 AM
Adam,
I’m sorry I can’t provide a link to the video. I actually emailed Marc to see if he knew which video that was in, but he wasn’t sure either. If you tell me what part is unclear, perhaps I can try to better explain it to you in more graphic detail.
View pintodeluxe's profile
pintodeluxe
5663 posts in 2814 days
#9 posted 11-23-2011 10:56 AM
Thanks for the tip. I have heard that one before, but it was overcomplicated in the version I read. Your description is much better.
Another technique I use on the planer to flatten wide stock: Hit and miss plane one side, then flip workpiece and plane smooth. Finally, using the smooth side as the reference edge, finish planing the first side. While this is not truly jointing, I have been amazed how straight a well-sawn board comes out. When I inspect a stack of boards milled this way, I often can’t tell the difference.
Thanks again, Great Tip!
View bjmh46's profile
bjmh46
5 posts in 2937 days
#10 posted 11-23-2011 01:04 PM
One thing should be mentioned:
If your 6” jointer has a rabbeting ledge, as most do, you must make a shim plate to be placed on the infeed table after the first pass. Otherwise the un-jointed width of the board will ride the rabbeting ledge. I use a 6” wide piece of 1/8” masonite with a cleat attached to keep it from being fed into the cutterhead.
Regards
View Adam's profile
Adam
#11 posted 11-23-2011 02:54 PM
Mike,
Thanks for trying. I think I need some pictures or video. For some reason I just can’t grasp it from a verbal description. I’m sure I will stumble across this method at some point.
Thanks,
Adam
Craftsman on the lake
2791 posts in 3438 days
#12 posted 11-23-2011 03:22 PM
Adam, what he’s doing is jointing part of the board to get 6” flat. Then applying plywood to the jointed part to raise the whole board up. From there he can plane the top side with the ply making the bottom flat. After the top is flat in the planer the original side with the raised edge can be flipped over and planed. It’s a way to trick the planer to think the bottom is flat. Nice technique.
Hmm.. does that help? I used to be a teacher of 30 yrs. Everything is a teachable moment. Damn attribute I can’t shake. I turned my kids into physicists at the dinner table by the time they were 15. I had very patient and understanding kids.
View pvwoodcrafts's profile
pvwoodcrafts
244 posts in 3922 days
#13 posted 11-23-2011 03:45 PM
I use this method all the time only I don’t bother taping it to a piece of plywood before running it through the planer. just try to get the outside edges and the center of the board close to straight across as possible so that it rides through the planer supported so that it only cuts off the hump .I run the humped side through the planer then the jointed side.
-- mike & judy western md. www. pvwoodcrafts.com pvwccf1@verizon.net
tenontim
#14 posted 11-23-2011 04:03 PM
I posted a blog, with pictures on how to http://lumberjocks.com/tenontim/blog/26637
View Adam's profile
Adam
#15 posted 11-23-2011 06:06 PM
Thanks Guys! Now I get it. Filed away for future use.
Adam
