Rip Blade on Table Saw
Forum topic by richgreer posted 11-20-2011 11:43 PM 2459 views 0 times favorited 16 replies Add to Favorites Watch
View richgreer's profile
4541 posts in 3003 days
11-20-2011 11:43 PM
I use a combination blade (WW II) almost all of the time.
However, I have a lot of ripping to do so I decided to try a true Rip blade. It does cut faster. Of course, its brand new and my other blade probably not quite as sharp.
I’m noticing something with this blade. I’m getting more sawdust coming out on the top of the table.
Is this normal for a rip blade?
16 replies so far
View grizzman's profile
7836 posts in 3232 days
#1 posted 11-20-2011 11:56 PM
i really dont know…i know when i do my cutting with the heart pine that i have, i get more sawdust then i do on other woods…i wonder if the dust collector is not doing as well as it should…i doubt its the blades fault…but …like i said im not sure…ill be interested to see what others have to say on this as well…..
-- GRIZZMAN ...[''''']
View 1yeldud1's profile
301 posts in 2971 days
#2 posted 11-21-2011 12:25 AM
Are you using a standard table saw insert or are you using a zero clearance insert ??? I notice my zero clearance insert lets more dust out (Im assuming the restricted air flow around the blade accounts for this)
View ajosephg's profile
1880 posts in 3490 days
#3 posted 11-21-2011 12:26 AM
A factor is blade alignment, but I don’t know why a rip blade would be worse than a combination.
-- Joe
View Dallas's profile
3599 posts in 2416 days
#4 posted 11-21-2011 12:53 AM
Rip blades have a larger gullet and are spinning toward you. When the blade come out of the insert and into the wood it’s taking off larger and longer shavings compared to the small sawdust that comes from a cross cut blade. This stuff weighs a lot more and also can hang out the sides of the blade so as it tries to go back into the wood or the insert on the descending side it has a tendency to be torn out of the gullet of the blade.
*Caution: I can’t prove this theory, but it sounds good. Also, I’ve looked closely at the different sawdust my blades put out and have notice a big difference between a cross cut and a rip blade. Also looked at different kerfed blades.
I have a spankin’ new Onsrud thin kerf rip blade that will take shavings off like a hand plane if I do it just right on a thick piece of Oak. I never seem to have problems with it leaving saw marks or burn marks.
#5 posted 11-21-2011 01:02 AM
Thank you for the responses. I think Dallas is on to something.
In response to some of the comments – - This is a relative thing. The rip blade is putting out more above the table saw dust than the combination blade I normally use. The dust collection would be the same for both and the blade alignment should be the same. I am using a standard table insert (not a zero clearance).
Another point – both my combination blade and my rip blade are narrow kerf – but I don’t see how that is a factor.
The wood involved has been both red and white oak.
View knotscott's profile
7926 posts in 3304 days
#6 posted 11-21-2011 01:45 AM
Dallas hit on what is probably the primary contributor, but differences in tooth grind could also play a role. A flat top grind (FTG) takes a full bite of the entire kerf width of the teeth.
View Bernie's profile
422 posts in 2766 days
#7 posted 11-21-2011 05:31 AM
To add on to what Dallas was saying (good stuff), rip blades are designed differently then combination or cross cut blades. Unlike the others, rip blades have teeth that follow each other in a thin straight line. Look at combination blades, one tooth is slanted to the right and the next is slanted to the left. I would think this gives room to chop the longer fibers, turn them into sawdust and thus into our dust collectors. Just an observation…
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
View BurtC's profile
103 posts in 3059 days
#8 posted 11-21-2011 06:51 AM
I too use the WW-II for everything. It is a great blade and performs to my expectation, but the saw on table top is much more with zero clearance insert. I figure this is why they have overhead type dust collection for table saws available? I found having an air filtration unit running nearby helps alot and of course, a mask is a must.
View TNwoodchuck's profile
102 posts in 3704 days
#9 posted 12-31-2011 05:21 AM
For what it may be worth, on my way to your post (after much researching of DIY ZCI’s) I came across a tip that I’m going to try that claims to reduce the dust caused by using a ZCI. The suggestion was to drill a 1/2 hole at the front of the ZCI kerf where the saw teeth move downward through it. This then allows room for DC air and dust to be drawn into the saw body properly by the DC system. Can’t wait to give it a try tomorrow.
-- Chuck near Nashville - “All you are unable to give possesses you” (Andre Gide)
View gfadvm's profile
14940 posts in 2619 days
#10 posted 12-31-2011 05:26 AM
Chuck, Please post the results of this experiment. Sounds like a good plan but I’ll wait to hear your results before drilling mine.
View David Craig's profile
David Craig
2137 posts in 3038 days
#11 posted 12-31-2011 05:38 AM
I think Dallas is spot on. Rip blades cut more aggressively, so they won’t be bogged down. Your cut is less refined, so the dust produced is less fine, which means that more of it gets trapped above the surface and is more noticeable.
View isu1977's profile
42 posts in 2802 days
#12 posted 03-03-2012 05:14 PM
I tried drilling a series of 1/4” holes (20) in my zero clearance insert and this help tremendously.
-- Cy - Des Moines, IA
View C_PLUS_Woodworker's profile
601 posts in 2836 days
#13 posted 03-03-2012 07:16 PM
I have both Forrest WWII and one of their glue-line rip blades. I have noticed this same issue before myself. I was intrigued by the ideas just mentioned about holes in the ZCI.
I just went out and used the stock insert that came with the saw (Unisaw). Large blade opening.
I used both crosscut and rip blades with that open insert.
Much less sawdust on the table top with either/both blade(s) than with my close-tolerance ZCI’s.
Didn’t notice much difference in amount of sawdust comparing either blade.
I am definitely going to drill some holes in my ZCI’s.
Thanks you guys.
#14 posted 03-03-2012 07:34 PM
But—- doesn’t drilling a hole in the ZCI defeat the whole purpose?
I thought the ZCI supports the wood to keep it from chipping as the blade comes down. If the support is removed, then chipping can occur.
-- Joe
#15 posted 03-03-2012 07:38 PM
You drill the holes about 1/4” – 1/2” from the blade slot. You will still have the support to prevent chipout. The holes allow more air to suck up the dust.
