Locating Compression Springs
Forum topic by RTim posted 550 days ago 594 views 0 times favorited 8 replies Add to Favorites Watch
View RTim's profile
RTim
60 posts in 862 days
550 days ago
Topic tags/keywords: hardware spring springs compression spring
I was leafing through an old issue of Shop Notes (#5) and I realized I could really use the Small-Piece Miter Box so I started building it.
I found all the hardware I need to build it except for the springs. None of my local hardware or big-box stores had the kinds of springs necessary. I found some on Amazon that were a good length and outside diameter but the wire size is too thick and my little gent’s saw cannot compress the springs with normal use. It will compress the springs if I press directly on the back of the saw but then you can’t make a cut so I’m kind of stuck.
Does anyone know of a spring supplier that sells hobbyist quantities of springs at resonable prices? Even 2 – 1” high springs stacked if they were 7/16” – 5/8” OD but only 1 – 2 lbs/in compression force?
-- Tim from MA -- "Well done is better than well said." - Benjamin Franlin
8 replies so far
View Bill White's profile
Bill White
2604 posts in 2130 days
#1 posted 550 days ago
Why not see if Shop Notes has a suggested supplier?
Bill
-- bill@magraphics.us
View Grandpa's profile
Grandpa
2381 posts in 845 days
#2 posted 550 days ago
what about McMaster-Carr
View RTim's profile
RTim
#3 posted 550 days ago
I had orignally thought of Shop Notes but they no longer carry the project parts kit and that was the only listed supplier.
I hadn’t originally thought of McMaster-Carr, but their springs are similar to what Amazon carried and far too thick a wire diameter for what this project requires.
Thanks for the idas though! Maybe I’ll have to email Shop Notes and see if they have a current supplier for the springs.
View JJohnston's profile
JJohnston
1394 posts in 1461 days
#4 posted 550 days ago
I don’t know what sort of size you’re talking about, but try Wolff gunsprings. They have some general purpose packs. If not Wolff, try Brownells (gunsmithing supply).
-- My broker promised me he would treat my money as if it were his own. Trouble is, he did.
View DrTebi's profile
DrTebi
88 posts in 1436 days
#5 posted 547 days ago
I was at some point hunting for compression springs as well, and bookmarked this page:
http://www.centuryspring.com/index.php
They have a huge selection, you can buy small quantities, but the minimum order is $40… not sure if that works out for you.
View Gregn's profile
Gregn
1643 posts in 1153 days
#6 posted 547 days ago
On page 31 they have a list of sources and at the bottom of the page is a mail order list of suppliers they used for the hardware in the projects they made in shop notes #5.
View RTim's profile
RTim
#7 posted 547 days ago
Thanks for all the suggestions folks. I sent an email to Shop Notes and they actually still have the springs in stock…for $0.75 each! I ordered the 4 I need and they’re being shipped today. Once they arrive I can assemble the miter box and post some pictures.
View 000's profile
000
3352 posts in 786 days
#8 posted 547 days ago
Ace Hardware stores carry a variety of small springs
-- When the moderator chooses sides, his site sucks.
