Do hold downs work for you?
Forum topic by crank49 posted 11-18-2011 08:22 PM 2151 views 0 times favorited 6 replies Add to Favorites Watch
View crank49's profile
crank49
4028 posts in 2844 days
11-18-2011 08:22 PM
Topic tags/keywords: question workbench accessories work holding
I guess this is a dumb question, but I got some cast, 3/4” hold downs at Woodcraft a while back and they don’t work for me.
My bench top is 4 layers of 3/4” plywood with a sacrificial top of 1/2” MDF and 1/8” hardboard. The total thickness, thanks to the magic of undersized plywood, is 3-1/2”. I drilled my dog holes 3/4”.
When I try to set a hold down with a good rap with a mallet (or hammer) it either dents my workpiece or just sits there, free as a bird. I never seem to get that wedge effect.
Any suggestions what might be wrong?
Would forged steel hold downs be better. I can see where they would have more spring than cast ones.
I work for a steel fabricator/general contractor and could make my own quite easily from steel rod.
Is it my bench top? Too thick? Too thin? Too soft?
View sandhill's profile
sandhill
2128 posts in 3797 days
#1 posted 11-18-2011 10:41 PM
I have a bench that is 2 layers of 3/4” Plywood and have no problem at all. The holes must be at a perfect 90 degrees. I am using hold downs I bought from Veratas only they are a bit expensive.. I always use a thin piece of scrap wood or leather to prevent marring my work because even if no marks are visible it compresses the wood and you may see it when applying the finish.
View CubsFan's profile
CubsFan
27 posts in 2887 days
#2 posted 11-18-2011 10:58 PM
I just got mine from Gramercy. They seem to work pretty well in a top which is 4 layers of 3/4” MDF. Though, I will need to find some leather or something to make sure they don’t hurt the wood.
View BobLang's profile
BobLang
149 posts in 3273 days
#3 posted 11-18-2011 11:05 PM
Are these made my Jorgensen, or a generic import? Jorgensens work well, the imports tend to either not work, or break when you hit them.
Your top is likely too thick. These things can be fussy, you might dry different thicknesses of stock to find what works. If you can, counterboring from the bottom side will effectively making the top thinner.
Bob Lang
-- Bob Lang, https://readwatchdo.com
BobLang
#4 posted 11-18-2011 11:05 PM
Bob Lang
View AlbertaJim's profile
AlbertaJim
47 posts in 2302 days
#5 posted 11-18-2011 11:09 PM
Two possibilities.
1. Check out Gramercy’s site for information about how to use their holdfasts. http://www.toolsforworkingwood.com//Merchant/merchant.mvc?Screen=NEXT&StoreCode=toolstore&nextpage=/extra/blogpage.html&BlogID=251 a. They recommend only a 3” top. Counterbore the bottom to make it 3” to give the holdfast room to grab. b. Also use coarse sand paper perpendicular to the shaft entering the hole. This gives a rougher surface to grab into the hole.
2. When I started using my holdfasts in my three inch top I noticed that I have to smack the holdfast toward the verticle peg. If I do it with my hand in this way it holds pretty well.
-- My Boss was a carpenter
View TheDane's profile
TheDane
5348 posts in 3536 days
#6 posted 11-18-2011 11:22 PM
I have the Gramercy hold-downs and they do a fine job for me. About 2 good raps with a mallet is all it takes.
My bench is Douglas Fir with a 3/5” thick top … when I drilled the dog holes (3/4”) I used one of those Wolfcraft Drill Guides to make sure I was going in at 90-degrees, and a masonite template to make sure I got the hole spacing where I wanted it.
Click for details
—Gerry
