Dust Collection Hook-up
Forum topic by teenagewoodworker posted 576 days ago 229 views 0 times favorited 7 replies Add to Favorites Watch
teenagewoodworker
2482 posts in 667 days
576 days ago
Topic tags/keywords: question
Hey Everyone, I just wanted to get some ideas about hooking up a connector to my miter saw so i can put a shop-vac on it. I have an idea in my head of how I’m going to do it but i wanted to get some other opinions on how to hook it up. Any help would be appreciated. here are the pictures of the dust shoot on the back of my miter saw. it’s just a little confusing for me to figure out a way to connect a hose to it.
some more information
the inside diameter is 2 3/16”
and the outside diameter is 2 3/8”
i think that the problem might be that the diameter of my shop vac hose is 2 1/4 instead of 2 1/2. i am getting a new one soon so if that is the problem it isn’t much of a problem.
Thanks for the help everyone!
View lew's profile (online now)
lew
4508 posts in 654 days
576 days ago
Dennis,
A couple of questions, what is the dust port on the saw made of? Also, what is the outside diameter of the port?
OK, A 2” PVC coupler should slip over the dust collection port of your saw. Maybe you could slip the coupling over the port and then slide your shop vac hose into the coupling. If the shop vac hose is too small to make a tight fit, a couple of turns of masking tape may do the trick. This is obviously not the best solution but mite work until you get a new vac and make a more permanent type of hookup.
Lew
View BarryW's profile
BarryW
872 posts in 805 days
575 days ago
Duct tape…always duct tape…or using PVC pipe…small sections…scrap from somewhere…create a wooden blast door or wood coupling…there are designs here and there to do just that. Think about a solution that doesn’t cost much money…and you’ll come up with an idea…maybe something you can create…I’m learning more and more that many of the products for sale were once solved with a wooden creation made by lumberjocks.
-- /\/\/\ BarryW /\/\/\ Stay so busy you don't have time to die.
View Al Killian's profile
Al Killian
271 posts in 652 days
573 days ago
Either duct tape or foam tape. This will take up the extra room and allow for a snug fit.
View Joey's profile
Joey
259 posts in 714 days
573 days ago
go to home depot or lowes. I think that I got mine at lowes. They sell a stepped adapter that fits random orbital sanders and miter saws. one end fits the shop vac and the other is is cut at the diameter of whatever tool you are trying to connect it too. I’ll try and get pics of mine for you. You will need some hose clamps just to connect it to the machine. They are about 5 bucks, but worth it. I’ve got them on my orbital sander and miter saw.
here is the link at lowes
http://www.lowes.com/lowes/lkn?action=productDetail&productId=37045-20097-9068711&lpage=none
and the item #37045 it’s called the universal tool adapter.
-- Joey, Magee, Ms http://woodnwaresms.com
View Garyswood's profile
Garyswood
50 posts in 619 days
572 days ago
with mine I just jam the hose in the back of the chute. Mind you though…it wont help all that much. the rate the chips fly out is much higher than the air flow will be able to cause them to change direction and get sucked in. However…it will get allot of the fine stuff. Best bet, use the saw in the garage or driveway and take a leaf blower to it afterwards….
Other option, put a dust collection shroud or build a box behind it and run your hose to that. It will collect more chips and the vac will get the fine stuff. Then you can vac up the chips.
-- Gary, Matthews NC
View Mark Shymanski's profile
Mark Shymanski
1555 posts in 611 days
572 days ago
I hooked up my shop vac to my Delta 10” and I agree with Garyswood, the rate the chips,dust etc come out of that wee port far exceeded my vacs ability to keep up. I actually went back to the little cloth filter bag that came with the saw as it was more effective then the jury rigged abomination I had on the end of my saw :-) It also looked less ridiculous :-) I think the problem was that the hose was too narrow and the airflow too low. Now I only had a mid size vac so maybe the larger ones are better at it? I used to take my saw outside, or dedicate an area that was somewhat isolated from stuff that I didn’t want to get covered in dust (the tool/bedroom combo in my last house as an example). I wound up using dust masks and vacuming up afterwards .
Good luck finding a solution, from what I’ve seen here you are pretty clever, you’ll figure it out.
View John Ormsby's profile
John Ormsby
503 posts in 636 days
572 days ago
A 2 1/2” flex hose is what you need to use. The port is designed to have the hose fit over the opening. You can secure it with a standard ring clamp from the plumbing department at home depot. Just make sure your new shop vac comes with 2 1/2” hoses. You would be better off to install a real dust collection system if you plan to do a lot of woodworking. They make clean up faster and the shop stays much cleaner.
-- Oldworld, Fair Oaks, Ca
