| Forum topic by NBeener | posted 547 days ago | 5928 views | 0 times favorited | 18 replies | ![]() |
547 days ago |
My friends got a new fridge, AND wanted to yank the laminate countertop, and install granite tile. I volunteered to help. The countertop thing is moving along swimmingly. The fridge is probably 1/2” too tall for the space under the upper cabinet. They figured it might be. All the upper cabinet tops are at the same level on the wall, so … they’re not keen on raising this one up, a skosh. They’re hardwood cabinets—probably Oak—including the “aprons.” So … I want to cut down the bottom apron … by the needed +/- 1/2”. My thought ? Just bring it back to my house, and do the four cuts on the TS, with masking tape on the cut lines, and a very fine (80t ?) blade. I also thought about the router table and a straight bit, or … just hogging it all off with the belt sander, and 80-grit paper, but … I keep coming back to the table saw. Any thoughts about the “best” or “right” way ?? I’ll check back, this evening … before I start in on it. Thanks ! -- -- Neil |
18 replies so far
#1 posted 547 days ago |
Neil, this brings back memories of last year (I’m too old to remember much after that!)... -- Don't let the perfect be the enemy of the good. |
#2 posted 547 days ago |
If you can get it off the wall in good shape, that will be half the battle. I think sending it thru the table saw, or using guides on a circular saw will be the way to go. I am assuming you will be only removing the needed area from the “bottom” of the cabinet, which will not be too visible to the eye. Should work out, good luck. |
#3 posted 547 days ago |
I would think you would have more control on the TS for this item. -- Don't rollerskate in a buffalo herd |
#4 posted 547 days ago |
did this with my brother in D.C. tape off the face run router with straight edge offset (or piloted template bit ) i guess it worked fine -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#5 posted 547 days ago |
Keep in mind that most fridges require an air gap of 1” above the fridge for proper function since the condenser coils are on the back of the unit. If you seal this tightly the fridge will not function correctly or have a shortened lifespan. Most all appliance manufacturers have installation guidlines on thier website that state how much air gap they need. Only true built-in fridges with front exhaust vents can be sealed tight to the cabinets. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#6 posted 547 days ago |
Hey Neil, depending on how much over hang the faceframe has you could just trim off at the bottom without running into the bottom shelf. However, watchout for unseen nail in the faceframe. Depending on how it was attached either with just glue, biscuits or nails you might run into that with a carbide tip and hurt the blade somewhat. Usually there is around a 1 to 1 1/2” of overhang on the bottom anyway so there should be enough room to trim. Just watch for appropriate air gaps for the fridge. The TS is the best way to trim it off. Just watch for metal on the way through. Good Luck. -- Drew -- "I cut it twice and it's still too short!"- Rock-n H Woodshop - Moore, OK |
#7 posted 547 days ago |
Neil, check the leg levelers on the fridge. They usually can adjust +/- 1/2” up or down. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#8 posted 547 days ago |
I set most uppers above the fridge at 72”. I have done the trim with a belt sander VERY CAREFULLY. Worked out well ‘cause I couldn’t take the stupid 12” deep uppers down w’out a major a$$ ache. Cab guys need to study the newer dims before design/install. -- bill@magraphics.us |
#9 posted 547 days ago |
Remove or adjust the leg levelers. If the fridge is on wheels.. remove them? -- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://gagnerwebsite.com/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html |
#10 posted 547 days ago |
I would use framing square and mark the line on all four sides, and cut it with a circular saw. -- CJIII Future cabinetmaker |
#11 posted 547 days ago |
I’m probably going to have to do the same thing when this fridge dies. The one the wife wants is to tall for the current opening. I wish you great success. I’d go with the table saw if it’s not to hard to take the cabinet down. -- Dan - Valparaiso, Indiana, "A smart man changes his mind, a fool never does." |
#12 posted 547 days ago |
I’d second Patron’s advice: “run router with straight edge offset with double tape (or piloted template bit ) Then a buddy to hold the vac close to the action for dust control. Good luck, Neil! -- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive |
#13 posted 547 days ago |
This is the kind of cut that is so quick and easy to do with a track saw, take it off, cut it, put it back up. -- Do or do not, there is no try |
#14 posted 547 days ago |
Take a handsaw with a very thin blade, or hacksaw if you suspect metal fasteners, and cut the bottom rail where it meets the side stiles. Pop off the rail and reinstall at the proper height. No finishing, cutting or running a router above your head sideways. -- http://www.niceashplanes.com/ http://www.efcabineture.com/ |
#15 posted 547 days ago |
Why take it down? They make tools for trimming cabinets…
-- It's the best woodworking show since the invention of wood... New episodes Wednesdays at: http://www.stumpynubs.com |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15749 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
