Humidity Rust?
« back to Hand Tools forum
Forum topic by laxbograt posted 580 days ago 546 views 0 times favorited 9 replies Add to Favorites Watch
View laxbograt's profile
laxbograt
76 posts in 624 days
580 days ago
I have noticed some of my metal tools have gotten rust on them even thought they have not gotten wet. I live in SW Florida and it is very humid here most of the year. I am curious if anyone else has had this problem and come up with a solution.
My shop is in my garage and unfortunately not climate controlled.
Carlos
Rookie Woodworker
9 replies so far
View childress's profile
childress
835 posts in 1740 days
#1 posted 580 days ago
wax….
-- Childress Woodworks
laxbograt
#2 posted 580 days ago
Bee’s wax?
I got a set of second hand router bits and they were dipped in a thick almost plastic coating? It is solid at room temp though? is that what they were dipped in?
Carlos
View bobasaurus's profile
bobasaurus
697 posts in 1382 days
#3 posted 580 days ago
Paste wax (Johnson’s, etc) is your best bet. I use it on most of my tools and other metal equipment, and it prevents all rust. You only really need to reapply once or twice a year (possibly more for high humidity environments, though).
View A10GAC's profile
A10GAC
141 posts in 1276 days
#4 posted 580 days ago
I’ll second Johnson’s Paste Wax and add some cloth covers. Just make sure the cloth covers are breathable and don’t touch the floor; this allows air to circulate and prevents condensation from building up under the cover.
-- A man who carries a cat by the tail learns something he can learn in no other way. - Mark Twain
View Drew 's profile
Drew
328 posts in 889 days
#5 posted 580 days ago
Johnson’s Furniture Polish or Beeswax is a nice rub on application that will prevent rust from humity problems. Also there is an anti rust spray you can get to just spray on the surfaces you don’t want to rust, however you will need to wipe off excess before using on wood. It will leave a stain.
-- Drew -- "I cut it twice and it's still too short!"- Rock-n H Woodshop - Moore, OK
View Bill White's profile
Bill White
2652 posts in 2158 days
#6 posted 580 days ago
All of the above, and good ventillation (as in a fan) will help. I’m in NE Mississippi, and have ceiling fans in the shop. There is also a product called “oil”. Not bein’ a smarta$$, but wipin’ things with a lube will help.
Bill
-- bill@magraphics.us
laxbograt
#7 posted 579 days ago
Thanks everyone,
I will probably try out the Johnson’s wax.
Bill: Yeah I am familiar with this “oil” you speak of, I also notice it has the habit of sometimes staining the wood that you are working on.
Still curious what the wax / “plastic” coating on the router bits I got were, it works great and must be a liquid that hardens or cures somehow. Anyone know what this product is?
Carlos
Rookie Woodworker
View Jeff in Huntersville's profile
367 posts in 1392 days
#8 posted 579 days ago
I second the Johnson’s paste wax. If I’m away for any amount of time I cover my larger machines up with moving blankets.
View BilltheDiver's profile
BilltheDiver
174 posts in 1083 days
#9 posted 579 days ago
I live in St Pete. Fl so I am familiar with your problem. Paste wax is good, but I prefer Boesheild T9. It was developed by Boeing to protect and lubricate airplane parts. It comes as an aerosol which you spray on, allow to dry, then buff off. I think it runs about $14 a can, but it lasts a good while and is a lot cheaper than elbow grease.
Sorry, I know what you are reffering to on the router bits but don’t know the name. The local guy who sharpens my saw blades uses the same stuff after he finishes them.
-- "Measure twice, cut once, count fingers"
