Resawing on the band saw
Forum topic by sarri_48 posted 11-17-2011 05:56 AM 1509 views 0 times favorited 2 replies Add to Favorites Watch
View sarri_48's profile
sarri_48
1 post in 2352 days
11-17-2011 05:56 AM
Topic tags/keywords: bandsaw resaw pine
I’m a woodworking student, I’m trying to find the best bandsaw blade to resaw 4” pine to 1/4” strips, I’m thinking skip tooth 1” blade or so with out a hook angle… thought?
2 replies so far
View ShaneA's profile
ShaneA
6912 posts in 2567 days
#1 posted 11-17-2011 05:59 AM
Will the saw accept a blade that wide? I doubt you will have to go that wide to cut 4” pine, a 1/2” 3 tpi woodslicer from highland woodworking or timberwolf blade should work just fine.
View richgreer's profile
richgreer
4541 posts in 3043 days
#2 posted 11-17-2011 05:04 PM
I don’t know how much pine you have to resaw, but I would not be too concerned about finding the best blade for this application. Virtually any bandsaw blade will do it. Pine is pretty easy to resaw – especially if is only 4” wide.
On my 18” bandsaw I use a 3/4” blade for resawing and a 1/4” for other applications. If I had to resaw just a few boards of pine I probably would not bother changing the blade from 1/4” to 3/4”. If I had quite a few boards to resaw, I would probably change the blade.
FYI – I really don’t like changing band saw blades on my big bandsaw.
