Qs about oilstones
« back to Hand Tools forum
Forum topic by Brett posted 11-17-2011 04:55 AM 1135 views 0 times favorited 6 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2648 days
11-17-2011 04:55 AM
Is an 8”x2” oilstone wide enough to sharpen plane irons? Should I use a 3”-wide stone?
I was given a small, old, greasy oilstone recently. Is there any way to figure out what the approximate hardness is? In other words, if it’s an Arkansas stone, can I tell if it’s a Washita, a soft Arkansas, or a hard Arkansas?
-- More tools, fewer machines.
View paratrooper34's profile
paratrooper34
915 posts in 2917 days
#1 posted 11-17-2011 11:53 AM
You will not be able to sharpen the big blades from a 4 1/2, 5 1/2, 6, 7, or 8 as they are 2 3/8 wide, I wouldn’t sharpen on a stone that couldn’t fit the full width of whatever I am sharpening. A 5 and a 4 have 2 inch wide blades which places them on the exact edge of a 2 inch stone. Get the big stone, you will be thankful for it. Good Luck
-- Mike
View hObOmOnk's profile
hObOmOnk
1381 posts in 4093 days
#2 posted 11-17-2011 02:48 PM
Your oil stone is either 8” long and 2” wide – OR – 2” long and 8” wide. It’s your choice. :)
Compare the stone’s grit to known grits of sandpaper.
-- 温故知新
View Don W's profile
Don W
18685 posts in 2533 days
#3 posted 11-17-2011 03:21 PM
I sharpen all mine on a 2” oil stone. Move the blade from side to side as you sharpen if you use a jig. When working freehand I skew the blade to fit.
I haven’t figured a way to tell how hard they are, but I compare the ones I find in the wild to a waterstone (4000 grit) i purchased. I hope someone has a better idea.
View StumpyNubs's profile
StumpyNubs
7578 posts in 2766 days
#4 posted 11-17-2011 04:00 PM
It will be perfect for 2” wide blades! if you want to sharpen wider ones, turn it sideways and take shorter strokes. Use a piece of wood the same thickness of the stone next to it for your angle guide to ride on.
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
View Dan's profile
Dan
3630 posts in 2845 days
#5 posted 11-17-2011 04:13 PM
“Danielson… Show me side to side” Sorry, Don’s comment made me think of that…
I often free hand sharpen side to side… Its more comfortable grip for me.
-- Dan - "Collector of Hand Planes"
Don W
#6 posted 11-17-2011 04:21 PM
I still haven’t got good enough to freehand a normal Stanley blade, the jig just makes it much faster for me. The thicker blades however I have. I can “feel” the contact with the stone. Also I haven’t figured out how to camber with the jig, so its a lot slower, but its freehand for me. The explanation here helped me a lot.
