New to Spraying, Need an Opinion
Forum topic by Sunnygirl posted 11-16-2011 09:53 PM 1418 views 0 times favorited 10 replies Add to Favorites Watch
View Sunnygirl's profile
Sunnygirl
37 posts in 2292 days
11-16-2011 09:53 PM
I’m getting ready to buy a turbine HVLP, have only sprayed one time in my life, so I’m trying to pick a good one. I’m trying to get the best one I can for my budget. I’m looking at the Earlex 6900 and the Campbell Hausfeld HV3000 (both 3-stage, I believe). I’ve read lots of reviews but still am not sure either one is very good. I would like to get the Fuji, but can’t swing the price. I will be spraying stains and finishes on cabinets, mostly waterborne. Would like to do latex paint occasionally, if possible. Does anyone have any insight to share on turbine HVLPs in this price range?
10 replies so far
View Robert Campbell's profile
Robert Campbell
3 posts in 3823 days
#1 posted 11-16-2011 10:47 PM
I understand your concern about the cost and quality of HVLP Systems you are considering. I own and operate a furniture restoration business, and have graduated to a Titan HVLP Turbin system. I enjoy the versatility of my unit, (I have a selection of 6 needles, tips and nozzles) which enable me to spray virtually any finish. I personally, have not had success at spraying waterbased stain. Of the two units you are considering, I would choose the Earlex 6900. The heavy hose used on these systems, took a while to get used to, but I now prefer my system to any compressed air spray system. I no longer need to be concerned about water/moisture collection in my hoses, and I don’t need to wait for a compresser to top off before I can start spraying.
View StumpyNubs's profile
StumpyNubs
7538 posts in 2709 days
#2 posted 11-16-2011 10:51 PM
Contact Charles Neil through his website. The guy has been finishing for near half a century and he’s known to give free advice! Here's the link. You won’t regret it, believe me! Plus, he has some DVD’s on it.
Tell him Stumpy sent you!
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
View CharlesNeil's profile
CharlesNeil
2267 posts in 3779 days
#3 posted 11-16-2011 11:52 PM
your asking alot from a single unit, especially at a lower price, the earlex 6900 is a nice unit, cant speak to the other one, the difference will be in the needle/nozzles you use for varying viscosities of what you are spraying, , latex paint, is far different in thickness than a water base dye, the difference will be in the needle /nozzle and the power the unit produces, the needle /nozzle set up for paint is far different than that which is used for a thin dye,
the simple answer is get what you can afford, and learn the limitations
View pintodeluxe's profile
pintodeluxe
5569 posts in 2722 days
#4 posted 11-17-2011 12:04 AM
I recommend a conversion type HVLP gun that operates off your compressor. I have been impressed with the Porter Cable gravity feed gun ($89), as well as the Wood River gravity feed gun ($39). They offer a very easy learning curve, and you will be quickly turning out high-end finihes.
Use the supplied 1.5 mm tip for lacquer and shellac
Use a 2.0 mm tip for latex paint ($10 extra)
Sunnygirl
#5 posted 11-17-2011 01:15 AM
Thanks for all the good advice. Pinto, do you know of a portable compressor that will work with those guns? I think the compressor is a good idea, but would like it a portable system.
404 - Not Found
2544 posts in 2878 days
#6 posted 11-17-2011 01:33 AM
A larger compressor is recommended for HVLP conversion guns due to the high airflow. I ended up getting the Fuji Mini Mite which is a terrific piece of kit, and has given me great results with waterborne, ac lacquers, acrylic and latex as long as they are thinned properly. For me, at the time, it was a big investment but consider how much time you will gain not waiting for finishes to dry and it will soon pay for itself (time is money, right?). I only wish I’d have bought it sooner and got the Q3 model (the quiet one) as the turbine is a bit of a screamer. A turbine system will also fit in a cupboard when not in use – and blow warm, dry, air – so you don’t get the associated moisture hassles of spraying when it’s cold and damp outside.
Sunnygirl
#7 posted 11-17-2011 02:00 AM
The Fuji gets great reviews. It’s already a stretch to get the 3 stage in the Earlex or Campbell, but will look a little more for a deal on a Fuji. If I find one, I’ll have to wear earplugs for awhile lol. It won’t be the Q3 at this point. Hope to upgrade in the future.
404 - Not Found
#8 posted 11-17-2011 02:12 AM
I realised I had to get some sort of spraying setup when I was trying to finish tri-fold plantation shutters in a cold, damp, February. Three days for oil based primer to dry. A day for each oil based top coat (x2) to dry. A whole week without being able to make any dust.
I made a similar job that I sprayed with waterborne coatings with the Fuji, done in a day and half and a much better finish to boot. The extra productivity is worth any cost.
Sunnygirl
#9 posted 11-17-2011 03:15 AM
Wow, that’s great. What a difference.
CharlesNeil
#10 posted 11-17-2011 04:12 PM
typically I use a 1.3 to 1.5 for most water bourne finishes, a 1.4 or 1.5 is pretty much standard for any application with exception to paints, then you need to look to 2.0 or larger , a 1.4 or 1.5 will handle lacquesrs , staind and dyes as well you will have to adjust the amount of fluid down for thinner materials like dyes or shellac, and open it up some for a WB finish,, good luck
