DeWalt 735 Question
Forum topic by Virgil posted 575 days ago 340 views 0 times favorited 6 replies Add to Favorites Watch
View Virgil's profile
Virgil
7 posts in 575 days
575 days ago
Topic tags/keywords: planer
Newbie here, my first post so hope I am on the right trail here. I should start out with an apology, as I have been lurking around for sometime on this site and have had many questions answered and picked up on some good advice. In fact based on many of your comments I just purchaced a DeWalt 735 Planer. I installed the Infeed and Outfeed tables and ran a few pieces of 1×6 through it and sure enough mine came with snipe included. Now, from previous postings I believe the idea is that you want the tips of the feed tables slightly higher than the center table. “My Question is, how much higher?” I put a straight edge across all three tables and the center section is almost 3/16 lower than the outer ends.
I should mention that the boards were just scrapes, maybe 24” long. Any help or advice would be much appreciated. I am looking forward to being part of the LJ’s group, seems to be a great variety of good people here.
-- If you don't make mistakes, your not trying!
View Suz's profile
Suz
51 posts in 654 days
575 days ago
First of all, welcome to the forum.
I also have a 735 and as much as I hate to admit some days I can run a piece of wood through the machine and never get even a hint of a snipe. Then on other days I cannot run a piece of wood to save my butt! (It must have something to do with the alignment of the planets and stars, the time of the day, or workshop Gnomes.)
Anyway, I think I’ve read where you should adjust the lift on the ends extension tables to about a thickness of a dime. (I wonder why money is always used to measure and adjust machinery? Who has any left after buying tools?)
When planing long boards on my Woodmaster I will lift the end of the board up to 6 inches higher than the bed to cut down on the snipe.
I guess it is one of those operator experience and “feel” thing. I don’t think there is any hard and set rule as to what height is the best.
-- Jim
View mrtrim's profile
mrtrim
1698 posts in 778 days
574 days ago
i seldom get snipe on my 735 except on long stock . i agree with jim on the feel method . i dont see why you would need any lift on a 2 ft. piece . that may be causeing your snipe thats just my opinion
Virgil
7 posts in 575 days
574 days ago
Thank You both for the input. I did adjust my tables down to the dime and it did help. Right now I have about a 1000 bf of rough 1×4 and 1×6 fir that I got from a local mill. This will give a chance to experiment and learn before I get into the $$ stuff.
Thanks, again—Virgil
View Thos. Angle's profile
Thos. Angle
4013 posts in 860 days
574 days ago
I never plane stock that is cut to size. I plane blanks and leave some to trim if there is a problem. I find that it actually saves me wood in the long run.
-- Thos. Angle
Virgil
7 posts in 575 days
573 days ago
Thos, Thanks for the input, makes sence. The stuff I got is Doug Fir and it is a full 1×4 and 1×6, I plan to rip a lot of it depending on the projects. It will most likely last me a long time.
By the way the outfeed table on your table saw, I have ordered the brackets from WC and I hope mine comes out nearly as nice as yours.
From the other Oregon, Virgil
View juniorjock's profile
juniorjock
790 posts in 663 days
573 days ago
Thos has the right idea. That’s what I try to do. I never bought the tables for the 735. I’ve found that if I lift up slightly on the back of the board on the infeed side and then do the same on the outfeed side I hardly ever see any snipe. Just experiment until you get a feel for it.
JJ
-- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood.
