Continuous grain picture frame
Forum topic by DaveMoore posted 11-14-2011 11:26 PM 3166 views 0 times favorited 9 replies Add to Favorites Watch
View DaveMoore's profile
DaveMoore
26 posts in 3471 days
11-14-2011 11:26 PM
Topic tags/keywords: question
I’ve made my head hurt trying to work this out, so maybe one of you guys can help me out :-)
Is it possible to have continuous grain on the face side of a picture frame with mitred corners? I can’t think of a way to make it work. Around the outside of the frame, continuous grain would be possible just like when building boxes, but it doesn’t seem possible to get continuous grain on the face side….unless i’m missing something…
What do you guys reckon?
9 replies so far
View mrg's profile
mrg
849 posts in 3235 days
#1 posted 11-14-2011 11:36 PM
You are going to need wood with a tight grain that is pretty straight or constsitant. Cross cut the sides to size then cut the meters on the ends. Reason being that you are not going to have the waste from left miter right miter. That will keep the grain a bit more consistent.
I hope that made sense. When doing a box you would do it the same way and loose the kerf which is on the corner.
-- mrg
View Bill White's profile
Bill White
5148 posts in 4196 days
#2 posted 11-14-2011 11:37 PM
Just cut the frame from a long board. Number the cuts to keep ‘em in proper order. Easy peesy! Think about wrapping a string around a box.
Bill
-- bill@magraphics.us
View PeteMoss's profile
PeteMoss
207 posts in 3706 days
#3 posted 11-14-2011 11:43 PM
If you take your stock, resaw it, then open it up, you will have two bookmatched strips. Lets say they are 40 inches long. Then if you cut one strip say 15 inches from the bottom and the other 15 inches from the top and open them up into a square, you will have a square 25 inches by 15 inches. Miter the corners and stick it together. Two corners will be continuous grain and two will be bookmached. More or less.
-- "Never measure......cut as many times as necessary." - PeteMoss
View phiflint's profile
phiflint
22 posts in 2854 days
#4 posted 11-15-2011 06:38 AM
Start with a board as wide & as long as you would like your picture frame to be. Cut a hole in the middle. Done.
View tenontim's profile
tenontim
2131 posts in 3980 days
#5 posted 11-15-2011 03:00 PM
I think I would get some sequenced veneer in the flavor of wood that I want the frame to be, then match your grain as mentioned above. With the veneer you’ll have several pieces that are almost identical. Make your base frame from the same species of lumber.
DaveMoore
#6 posted 11-15-2011 05:05 PM
ok, think i got it….I was worrying too much about the pieces that are “lost” when mitering, but i guess if the grains reasonably straight them it shouldn’t be a big issue
Tim, these are the first picture frames i’ve made, and i’ve no experience with veneering, so one step at a time I think :-). I’ll keep it in mind for the future though, thanks
tenontim
#7 posted 11-15-2011 05:28 PM
Dave, when you decide to try some veneering, I posted a blog awhile back, that shows how to veneer using an iron, instead of clamping or vacuum pressing. http://lumberjocks.com/tenontim/blog/8856 Try it out, it’s a fun way to get into veneering.
DaveMoore
#8 posted 11-19-2011 03:25 PM
Tim, very nice article, thanks. I’m going to stick with solid wood for the picture frames, but I do have a couple of ideas for veneered projects in the future, so it may come in very useful.
View buckles's profile
buckles
24 posts in 2778 days
#9 posted 11-21-2011 04:22 AM
Dave
Take a board that is as long as one side and one top piece.
Resaw the board length wise and mark the pieces.
Stand all four pieces on edge just like they came out of the resaw.
Move the upper left piece directly away from you
Move the lower right piece directly towards you
Move the lower left piece to your left
Move the upper right piece to your right
Now move each one so they form a square.
Now take and lay each piece down so that the top of each piece is towards the inside of the square.
Miter each end.
Regards
Joe
-- Politicians are like diapers. They need to be changed for the same reasons.
