| Forum topic by piesafejim | posted 582 days ago | 916 views | 0 times favorited | 9 replies | ![]() |
582 days ago |
Awhile back I started using shelac as a sealer for my projects, usually to be topcoated with laquer or water based poly. I am working on some curly maple pieces and i want to stay with shelac only. My delima is no matter if i brush or wipe on I am still not happy with the final result. My question for all you LJ’s out there is what do you use for your final sanding or how do you wet sand shelac or can you….. I anxiously await your answers. |
9 replies so far
#1 posted 582 days ago |
It dries so fast avoiding lap marks can be tricky. You can try using a If brushed or wiped on, sand lightly between coats and let the |
#2 posted 582 days ago |
what do you mean when you say “not happy with the results”? what arent you happy about? I noticed lately that several people mentioned they are having problems with shellac but am not sure why as it is of the easier finishes to put on. I will usually use a rag and ball it up (stretching the part touching the wood though) and wipe the finish on, wait for it to dry and sand with 320 between coats, rinse and repeat. last coat 400grit or 600, or light rub with steel wool when wiping the edges you want to wipe ‘outwards’ (from the center of the part out) and not ‘inwards’ to avoid runouts and spills on the adjacent edge. If it dries too fast on you, try thinning it down, and lightly overlap strokes. I wouldn’t worry much about marks during first coats as each additional coat will blend with the previous one – as long as you buff out the last coat properly you should be ok. -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#3 posted 582 days ago |
Look up numerous sites about “french polishing”. Lots of info available. The final result is beautiful. One of the classic finishes. It takes a lot of practice, but any errors can be reversed. That’s the beauty of shellac. -- bill@magraphics.us |
#4 posted 581 days ago |
I have a problem with dry sanding. The paper will gum up. I wet sand between coats, with a little dish soap, and get great results. Once you get to your final grit you can wax it nicely. -- Superdav "No matter where you go - there you are." http://chiselandforge.com |
#5 posted 581 days ago |
Superdave. If your paper is gumming up, you are not waiting long enough for the shellac to cure, or you are sanding in one area too much. Shellac should sand off into a really nice powder and be super smooth to the touch. I generally brush on my shellac, and I cut my own, I use about 1.5lb/cut. I can usually get the first two coats on right after the other, and then you just have to be really careful with the next few coats sanding in between of course as mentioned above. Then for the last 2 or 3 coats I switch to the LV french polish which I apply with a wadded up rag. Wait at least 5 days to a week, then I rub it out with 0000 steel wool. |
#6 posted 578 days ago |
As a beginning woodworker I also questioned the proper application for shellac in this forum. It seems what little I did know was the correct way. I apply my shellac straight from the can with either a foam brush or a pad. I take one swipe with the grain until the project is completely done. I then wait 2-3 hours to lightly sand it down with 320 SP block, blow it off with canned air, wait for 30 minutes for the dust to settle, wipe it down with a tack cloth and once again apply a light coat of shellac. I do this at least 3 or 4 times then wait until the next day to apply wax with #0000 steel wool. Do not let the wax dry, wipe it down with a soft cloth immediately. Actually I use a Bounty paper towel and the finish comes out slick and deep. I also read somewhere that applying a light base coat of BLO before applying the shellac was acceptable or recommended. Going to try that with my next project. -- If it won't fit get a BIGGER hammer. |
#7 posted 577 days ago |
TBH I think the best surface is generated from a well tuned hand plane. Sand paper damages the fibers of the wood so much in comparison that you lose alot of figure. Using a high angle plane or putting a back bevel on your plane iron prevents tear out. This is a much more dificult process but nothing beats it. As far as putting down shellac I just found a great tutorial on french polishing : http://www.milburnguitars.com/fpbannerframes.html A simpler method is taking a cotton cloth like a t-shirt that is ripped up, cutting into small squares, and folding up in a way so you have a rounded smooth edge of the cloth to work with. Dip and gather a moderate amount of shellac, you want to put on thin coats but fill the pores as much as possible. With maple you will not need to use pumice or a filler to build a polish, which is still a more difficult process I have yet to dive into. Wipe on a thin coat in a pattern you are comfortable with, the thinner you mix the shellac the longer you have to work with it until it will drag. I strongly recommend mixing your own shellac with denatured alcohol or anhydrous alcohol. I use denatured but anhydrous apparently reduces the water content and extends shelf life slightly. Try to keep your coats as even as possible but do not go back and try to touch it up after the shellac starts to pull. You may need to rewet your rag as well. After your first coat dries, which will be rather quick, LIGHTLY sand with 320 or 220 grit sand paper, or scuff with a scotch bright. This depends on how even your coat is and what cut of shellac you use. Cut is how thick or thin you make the shellac flakes with alcohol. Continue this process until you start to build a smooth surface. Check every coat to make sure everything looks even and uniform as well as doing the blind man test, feeling the surface. If the surface pulls even slightly, when you sand or scuff wait for the shellac to dry longer. The goal is to get the surface uniform enough until you only have to buff between coats. To buff I use a brown paper towel folded so there are no ridges. A brown grocery bag seems to work well too. Eventually you should be able to buff the finish itself in to an extent, but you have to work quick. The final finish is buffed with the paper towel or scuffed with a scotch bright to get a more matte finish. There are many ways to use shellac, this is a simple way I’ve used. I have a project I am getting photographed soon I finished a few days ago that I used this finish on. -- Byron Conn, Woodworking/Furniture Design at Rochester Institute of Technology, http://byronconn.com |
#8 posted 577 days ago |
I am working on a project right now and I put on a coat of BLO and then immediately put on shellac. I am using amber straight from the can. It is a little difficult because of the edges on the pieces, but if you get a run just lightly sand and apply another coat. I am not going for a french polish finish. I just put on 3 coats and wax. Rubbed out with 0000 between coats. I am using this on teak and it is beautiful. -- Chief Petty Officer USN(RET) 1991-2011 |
#9 posted 576 days ago |
How old is your shellac? It does have a shelf life. -- Don't rollerskate in a buffalo herd |
| Forum | Topics |
Woodworking Skill Share
8845 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15977 |
Hand Tools
2093 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2775 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
