Tips & Tricks: Wood Movement
Forum topic by MsDebbieP posted 11-14-2011 12:13 PM 1244 views 0 times favorited 1 reply Add to Favorites Watch
18615 posts in 4125 days
11-14-2011 12:13 PM
Topic tags/keywords: wood movement tips tricks
What are your tips/tricks re: Wood Movement?
- why does it happen? – how do you plan for it?
(also add links to helpful blogs etc that are related to the topic)
Gateway to all Tips & Tricks Topics
1 reply so far
View OldLarry's profile
OldLarry
18 posts in 2128 days
#1 posted 08-17-2012 11:59 PM
Wood moving “in service” is due to a change in moisture content. In most parts of the country you should start your hardwood projects with 6 – 6.5% moisture. You can find charts online that show how much movement to expect. Buy a meter. Wood changes more on flat sawn boards than on edge grain up boards, quartered. There is no significant change in length.
I don’t think you can air dry hardwoods to the point they will be stable indoors.
There is an excellent book on the subject by Gene Wright, the Wood Doctor.
Another book is by Bruce Hoadley.
Wood that moves as you rip it is usually suffering from tension fibers. not much can be done with that. Best not to use it.
Larry
-- Larry, Nebraska
