Question on finishing
Forum topic by Drillbit posted 05-01-2008 03:49 AM 938 views 0 times favorited 6 replies Add to Favorites Watch
View Drillbit's profile
Drillbit
5 posts in 3712 days
05-01-2008 03:49 AM
Can i poly over tung oil?
View GaryK's profile
GaryK
10262 posts in 3985 days
#1 posted 05-01-2008 06:22 AM
Sure
View Dadoo's profile
Dadoo
1789 posts in 3987 days
#2 posted 05-01-2008 08:13 AM
I dunno…if it’s just regular Tung oil then yes…using an oil based poly. But I’ve got some Formby’s Tung Oil and it contains shellac as well. Actually, I guess you can poly over just about anything, just about. Except…
27250 posts in 3819 days
#3 posted 05-01-2008 12:08 PM
Absolutely. Just give it a light scuff sanding with 220 before applying the poly.
Drillbit
#4 posted 05-02-2008 12:33 AM
Thanks alot guys i appreicaite the info
teenagewoodworker
2727 posts in 3765 days
#5 posted 05-02-2008 01:05 AM
ya you can, they are both oils so they are compatible. to be safe though whenever i put anything under poly i put a coat of dewaxed shellac (bullseye sealsoat). its just precautionary but i like to do it.
View Joey's profile
Joey
276 posts in 3812 days
#6 posted 05-02-2008 02:29 PM
I mix poly with tung oil. It helps the tung oil to dry faster and gives a little more protection.
You can also mix equal parts poly, pure tung oil, and boilded linseed oil. It’s easy to wipe on and off and according to my 7 year old daughter, has the best feel of any finish that I use.
-- Joey, Magee, Ms http://woodnwaresms.com
