Any tips on finishing rough cut lumber
Forum topic by Tim_Beyer posted 583 days ago 2752 views 0 times favorited 4 replies Add to Favorites Watch
View Tim_Beyer's profile
Tim_Beyer
24 posts in 1568 days
583 days ago
Topic tags/keywords: stain rustic pine
Does anyone have any tips for finishing rough cut. I am in the process of building a dining table out of rough cut pine and am wanting to have the rustic look to it. I did some test samples on the scraps but wasn’t overly impressed with the look. Any tips or tricks would be appreciated.
Thanks
View ScottN's profile
ScottN
259 posts in 876 days
#1 posted 582 days ago
Try using pre stain conditioner and a spray gun for applying the stain to have more of a uniform coat.
-- New Auburn,WI
View cabinethawk's profile
cabinethawk
1 post in 582 days
#2 posted 582 days ago
That is kind of a ‘loaded question’. I guess I’m not sure what you mean by ‘finishing’. If I wanted to make a Dinning Table out of rough cut limber I would still make the working surface a highly sanded and buffed, stained, waxed surface. I would probably do a little smoothing on the sides, and legs. I would spray the same stain as the top. I would use a low luster polyurethane or just tung oil. A good natural looking finish is a mixture of tung oil, boiled linseed oil, and polyurethane mixed in equal parts making sure you wipe off the excess after a few minutes.
View Bill White's profile
Bill White
2649 posts in 2157 days
#3 posted 581 days ago
I built one from old eastern white pine from floor joists. Skip-planed it to leave some saw marks and bug holes, kinda champhered the jointed edges to highlight the joints, sealed it with shallec (Zinsser Seal Coat), stained it by using a toned poly with TransTint, final finish with a satin poly that was rubbed and waxed. The base was paint/glazed/distressed/clear coated.
I know. I hate poly anything, but there are times when it is appropriate.
Just my method.
Bill
-- bill@magraphics.us
View Daver725's profile
Daver725
13 posts in 533 days
#4 posted 533 days ago
I’ve had good luck with oil finishes, but usually of almost finished sanded. Not sure how well it would work if you left it totally rough. If you wanted to do that I would guess some sort of clear epoxy would work best.
Dave
-- Insanity, doing the same same thing over and expecting different results.
