| Forum topic by Max | posted 127 days ago | 304 views | 0 times favorited | 15 replies | ![]() |
127 days ago |
Topic tags/keywords: question finish shellac orange knotty pine I put new windows in my basement and needed to replace the pine jambs and casing. I am now needing to match the finish to the existing walls. This paneling was put up in the 50’s or 60’s and I assume that a orange or amber shellac was used, but I am not sure. Any ideas??? The picture is of the paneling in the basement. -- Max "Desperado", Salt Lake City, UT |
127 days ago |
That has lots of red in it! Good luck. |
127 days ago |
Hi max i may be wrong but have you ever used tea bags for staining you may get the aged look your looking for let me know how you get on with what ever method you use thanks pommy -- cut it saw it scrap it |
127 days ago |
It does have a warm orange tint to it. The picture makes it look redder than it is. There are quite a few homes in my area that have this same paneling in the basement, but most all of the original owners have passed away. My Dad’s house has it in it also but he passed away in December. I really don’t think that it was stained but don’t know for sure. -- Max "Desperado", Salt Lake City, UT |
127 days ago |
I had the very same issue a few years ago when I added new knotty pine in parts of my lake place. The original pine was done in the 1950’s and I ended up getting a couple of different stains (all the same brand, so therefore compatible) in different shades. I mixed until I had the best match and then put a finish on to make sure it dried to a match. I finished with a polyurethane that’s not suppose to darken with age so, in theory, the match will last. Good luck. -SST -- Accuracy is not in your power tool, it's in you |
127 days ago |
Try some different shades of shellac. Orange shellac will get you close. You may have to put several coats. Once you get the color you want, seal it with poly. -- Tim -- http://tmuli.com |
127 days ago |
I kind of thought that it might be orange shellac that had aged for quite a few years. I can find amber shellac which I assume is the same as orange shellac?? -- Max "Desperado", Salt Lake City, UT |
126 days ago |
These guys have more shellac than you might want to see. http://www.shellac.net/ -- Tim -- http://tmuli.com |
126 days ago |
tenontim Thanks for the link. You are right they have it all….. -- Max "Desperado", Salt Lake City, UT |
122 days ago |
shellac would be my first choice … garnett or buttonlac -- ..... art for lifes sake |
121 days ago |
Dan, I got some Amber shellac I was going to try but I am not sure it will be dark enough. I am sure over time it will darken. -- Max "Desperado", Salt Lake City, UT |
121 days ago |
Go ahead and do the shellac and when that is all dry determine if you need more red, yellow or both. Then go buy some tubes of oil paint, raw sienna and perhaps some red. Start mixing it little by little with turpentine until you get the color you desire and start rubbing it on the pine. It takes a while to dry, but you can just about match any color you want with the oil paints in the turpentine. Before Home Depot or the local hardware store it was a method to make your own stain. -- There is no such thing as scrap wood!, http://www.saltrivergallery.com |
121 days ago |
Brian, I had not thought of that…. Thanks I will give it a try.. -- Max "Desperado", Salt Lake City, UT |
121 days ago |
I have knotty pine paneling just like yours-my house was built in ‘54. Orange Shellac, several coats, will work. -- Gerry |
121 days ago |
Max -- ..... art for lifes sake |
121 days ago |
Gerry, I believe that is what was used here and also in my Dads house was orange shellac (amber shellac). -- Max "Desperado", Salt Lake City, UT |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1141 |
1528 |
103 |
299 |
96 |
Woodworking Trade & Swap
211 |
Coffee Lounge
838 |
LumberJocks.com Site Feedback
256 |
