Understanding Bench Vises
Forum topic by SeaWitch posted 11-12-2011 10:01 PM 4675 views 0 times favorited 14 replies Add to Favorites Watch
View SeaWitch's profile
SeaWitch
149 posts in 2359 days
11-12-2011 10:01 PM
I’m considering building a new workbench and adding one or more proper vises, but I barely understand the differences. Can anyone explain to me the pros and cons of the different workbench vises? Which do you have and like and why or which do you wish you had? The sliding tail vise, for example, looks so small….I don’t see the great benefit of it.
thanks
-- When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it.”   Theodore Roosevelt
14 replies so far
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3079 days
#1 posted 11-12-2011 10:25 PM
don´t underestimate the power of having a tail wice or the shuolder vice
but witch wice you want to have is all a matter of what you want to make
and from where you come from / used to use
they all have there pro´s and con´s
here is a link to a vidio clip that might demystyfire it a little
http://woodtreks.com/design-build-traditional-woodworking-workbench-tail-shoulder-leg-vises/1651/
beside that there is a few books out there about workbenches of all kinds that should be able
to help you
take care
Dennis
View Bill White's profile
Bill White
4902 posts in 3925 days
#2 posted 11-12-2011 10:33 PM
I have a tail vice (right end) with an added “face” that is the full width of the end of my bench and a shoulder vice (left front edge) with a wood jaw (face) on the end of the front of the bench. Both jaws are drilled for bench dogs (not to be confused with shop dogs).
Leftys sometimes reverse the location of the tail/shoulder vices.
The surface of my bench is drilled for dogs 6” on centered. Sure gives me plenty of flexibility for bench work.
Bill
-- bill@magraphics.us
SeaWitch
#3 posted 11-12-2011 10:37 PM
Thanks Dennis and Bill. I’ll watch that video. Bill, what do you mean by the “jaws are drilled for bench dogs”? I thought bench dogs were used on top of the bench?
Dennisgrosen
#4 posted 11-12-2011 10:52 PM
its so you can use the bench dogs to hold your peices of wood with
but it will be shown in the vidio as I remember
Dennis
View mcase's profile
mcase
446 posts in 3093 days
#5 posted 11-14-2011 04:03 AM
Most conventional vices wrack and are of little use. A true shoulder vice is a direct pressure screw and so avoids this. The other option is the Veritas twin screw vice. This Veritas replaces the center screw and side slides with two chain-driven twin screws so as to apply immense pressure without wracking. The Veritas can be mounted across the end of the table or the front and can be set with a series of bench dog holes.
SeaWitch
#6 posted 11-14-2011 04:49 AM
I watched this video—thanks to dennisgrosen and the guy in there has a vice with a face that swivels or articulates. I never hear anyone mention a vice like that, but he says it’s great for holding odd shaped things. Any comments on that?
Dennisgrosen
#7 posted 11-14-2011 03:26 PM
in some cases its and advance to have it , in my shuoldervice I havn´t as much as he has in his
the face plate is needed on a shouldervice to avoid maring your work pieces with the screw
most vices do it when you place a piece of wood to one of the sides of the mainscrew
not so good for the vice .. what you do is make woodpieces with different thickness
that can hang over the edge of the vice …. so you can use one to align the vice
and press equal to each side on the vice …. this will gives a lot longer life to the vice
Dennis
View TheDane's profile
TheDane
5399 posts in 3627 days
#8 posted 11-14-2011 09:23 PM
FWIW … my bench has both a tail and a face vise … I wind up using the tail vise about 90% of the time.
—Gerry
View Tedstor's profile
Tedstor
1643 posts in 2597 days
#9 posted 11-14-2011 10:08 PM
My bench currently has only a tail vise w/ dog holes on either end. I use it to secure longer boards and/or benchtop machines. I’m going to add either a steel front vise or a leg vise in the near future.
FWIW, I tend to use power tools and only use hand tools when/if it makes sense to. IMO, heavy hand tool users need a fancier vise array than power tool guys like myself.
View crank49's profile
crank49
4030 posts in 2935 days
#10 posted 11-14-2011 10:17 PM
Nobody mentioned a patternmakers vise.
View KayBee's profile (online now)
KayBee
1083 posts in 3211 days
#11 posted 11-14-2011 11:07 PM
The shoulder vise has the face that swivels. There are no guide bars in the way, so you can use the entire surface of the face for clamping. They’re not ‘in fashion’ any more. Most people don’t like how the shoulder sticks out. You keep running into it with your hip : ) Mostly, it depends on you, your style of work and what you’re making.
Try reading “The Workbench Book” by Scott Landis for an good overview of different styles of benches and vises. Christopher Schwarz has two bench books also.
-- Karen - a little bit of stupid goes a long way
SeaWitch
#12 posted 11-15-2011 12:31 AM
Thanks so much for everyone’s help. I’d like to have the swivel face on the shoulder vise. Any idea where to get one of those screws with the swivel face? I’m migrating to hand tools, so I think I will really take advantage of the vises.
View Brit's profile
Brit
7369 posts in 2807 days
#13 posted 11-15-2011 01:04 AM
My advice is not to start building your bench until you understand the advantages and disadvantages of each vise design. In my opinion, for hand tool work, you cannot beat a roubo style bench with a wagon vise and a leg vise. These two vises are the best for dimensioning stock by hand. Then add a bench on a bench with a twin screw vise for holding long boards on edge for dovetailing etc. This also raises the height of the workpiece to a height that is comfortable for joinery work.
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
SeaWitch
#14 posted 11-15-2011 01:07 AM
Brit, you’re absolutely right, and the Roubo is what I’m going to build after the holidays along with some others on a different ww site. That’s why I’m doing my homework now before deciding on the bench vises.
