How would you join this?
Forum topic by Chris posted 11-12-2011 06:39 PM 1712 views 0 times favorited 24 replies Add to Favorites Watch
View Chris 's profile
Chris
1879 posts in 3958 days
11-12-2011 06:39 PM
Topic tags/keywords: olive slab joint maple coffee table
I recently came into possession of a beautiful Olive slab (5ft x 18”). It has natural edges and begs to be the absolute focal point of what I build with it.
Having said that I am designing a coffee table and want to have a structure that isn’t to square and heavy to the eye. This is what I am considering….
They are going to be cut from Hard Maple for the strength and lack of grain character. My problem is how to join the upper and lower section of each leg assembly.
As I have only built case work prior to this I seek your insight and welcome your opinions.
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
24 replies so far
View richgreer's profile
richgreer
4541 posts in 3042 days
#1 posted 11-12-2011 06:59 PM
Option 1
I would drill holes from the bottom that go almost, but not quite, all the way through both pieces. Then I would drive dowels, with glue, into those holes.
Two dowels is probably enough, but I would use 3 for good measure.
Option 2
Drill holes with a Kreg (stepped) drill bit from the bottom. The shoulder of the drill bit should go about half way through the bottom piece. Use Kreg screws to secure the connection. Plug the holes. I’d use 4 or 5 screws with this approach.
View ShaneA's profile
ShaneA
6910 posts in 2565 days
#2 posted 11-12-2011 07:08 PM
I like option 2 from Rich, if no kreg setup, a forstner bit then pilot holes, quality screw, then plug the hole w/proper sized dowel
Beginningwoodworker
13345 posts in 3640 days
#3 posted 11-12-2011 07:15 PM
Screws might be the best bet.
View TMcG's profile
TMcG
191 posts in 2968 days
#4 posted 11-12-2011 07:22 PM
You could get a pretty nice mortise & tenon across that 6”, pegged would make a nice accent as well perhaps ?
-- http://wood.mcgivern.org
View Sawdust4Blood's profile
Sawdust4Blood
403 posts in 2989 days
#5 posted 11-12-2011 07:27 PM
Rich’s idea will work for joining the two parabolas. I would be more concerned with lateral strength though.
-- Greg, Severn MD
View HamS's profile
HamS
1829 posts in 2356 days
#6 posted 11-12-2011 08:38 PM
I think I would put a stretcher between the leg sat the joint. If you have any scraps of the olive wood left after whatever trimming you have to do it might be an interesting touch to put a double dove tail right at the intersection of the arcs of the leg with a bit of the olive wood.
-- Haming it up in the 'bash.
View interpim's profile
interpim
1170 posts in 3426 days
#7 posted 11-12-2011 08:39 PM
not sure how set on the design you are, but what if you overlapped the apexes and did a half lap… if you don’t understand what I’m talking about, imagine the top arch and bottom arch overlap enough to create a small football shape in between the two parts.
-- San Diego, CA
Chris
#8 posted 11-12-2011 08:44 PM
How do you mean Greg?
Chris
#9 posted 11-12-2011 08:45 PM
Interpim,
I hadn’t thought of that one; it has interesting possibilities.
Chris
#10 posted 11-12-2011 08:47 PM
FYI I will have a stretcher between the sets of legs….
Rich, I like the dowel idea. Was thinking possibly a loose tenon type of joint as well. But, I do see how the screws actually might be easier to pull off.
View DLCW's profile
DLCW
530 posts in 2621 days
#11 posted 11-12-2011 10:36 PM
I think I would use a combination of dowels and screws to hold it together. Probably 1/2” dowels and #12 screws. I would use epoxy in the joint to add some additional strength to the dowels and screws.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
View Bill White's profile
Bill White
4907 posts in 3928 days
#12 posted 11-12-2011 10:54 PM
YOU SUCK!!!!!
How dare you show us that wonderful piece of wood?
Be sure to send pics of the finished table. Man, that’s gonna be special. I wish I had your quandry.
Bill
-- bill@magraphics.us
View Howie's profile
Howie
2656 posts in 2890 days
#13 posted 11-12-2011 11:08 PM
I’d go with the dowels or loose tenons. I think you would gain more strenght in the joints.
-- Life is good.
Chris
#14 posted 11-12-2011 11:13 PM
Bill,
That “Quandry” came at a price. :) I will post the project though
Sawdust4Blood
#15 posted 11-13-2011 03:27 AM
okay Chris, the stretcher answers the question. As I was looking at the second of your design drawings, I see strength against a force coming down parallel to the blue axis and I see sufficient strength against a force coming parallel to the red axis, but without the stretcher I didn’t see anything to keep the two sets of legs from collapsing against a force coming parallel to the green axis. The stretcher should serve that purpose.
-- Greg, Severn MD
