expansion joints on wood fascia boards
Forum topic by sam1140 posted 11-11-2011 09:49 PM 7531 views 0 times favorited 6 replies Add to Favorites Watch
View sam1140's profile
sam1140
9 posts in 3010 days
11-11-2011 09:49 PM
I am replacing the fascia board in my home with 1×8 pine wood. The south wall alone is 83’ long, I am using 16’ & 12’ boards, they will be attached to the 2×6 rafters. I am planning to use 45 cut to joint the boards. I am confused about expansion joints, if I use 45 to joint the boards how you leave a gap?
(1) Can I joint the boards tight or leave a gap? (2) Is it better to joint the boards with a straight cut and leave a gap? (3) If I have to leave a gap, do I fill the gap with putty? (4) I received conflicting advise concerning nails or screws. Since I have to do 250’, I would like to know what is best to use, screws, casing nails, or round head nails? I have a cordless paslode nailer I can use, or rent an air hammer if I have to, also what size nails or screws should I use?
I don’t mind using round head nails and pain over them. To counter sink and putty so many nails would take me forever. Any advise and help will be greatly appreciated.
View Don W's profile
Don W
18988 posts in 2740 days
#1 posted 11-11-2011 11:04 PM
I’ve dona a lot of facia boards in my life. Here is the way I did them. 45 the joint. The 45 will allow enough movement for the facia. Nail with #8 or #10 galvanized nails. I prefer #8. Don’t leave a gap. The joint should always fall on a rafter. I typically used a nail gun, but hand drives will work. If you were going to leave the wood clear or stained get siding nails, they have a smaller head.
sam1140
#2 posted 11-12-2011 04:17 AM
Thank you for your reply. I am painting the boards. Concerning the nails, are they round head or the small casing nails? I can get galvanized nails with round head for my framing cordless paslode nail gun.
Don W
#3 posted 11-12-2011 03:31 PM
galvanized nails with round heads for my framing cordless paslode nail gun will work just fine
sam1140
#4 posted 11-12-2011 11:05 PM
Thanks again for your help, using the paslode, I don’t have to rent another nailer.
View WDHLT15's profile
WDHLT15
1786 posts in 2648 days
#5 posted 11-14-2011 04:54 AM
Don’t leave a gap. Bevel the joint on a 45 degree bevel. Wood does not shrink or swell longitudinally (lengthwise).
View JimDaddyO's profile
JimDaddyO
575 posts in 3251 days
#6 posted 11-14-2011 02:57 PM
also: face your joints so that from the most viewed angle you look “over” the joint and not “into” the joint.
looking———->/__
where the underline is the back ( the side you do not see) of the facia, and the / represents the angle of the joint.
-- my blog: http://watertoneworkshop.blogspot.ca/ my You Tube channel: https://www.youtube.com/channel/UCA5AretE3xPoVDV61AxUdUA?view_as=subscriber
