Handrail mitering
Forum topic by gthang posted 11-11-2011 01:14 AM 6804 views 0 times favorited 4 replies Add to Favorites Watch
View gthang's profile
3 posts in 2319 days
11-11-2011 01:14 AM
HI, Im having trouble mitering a handrail. “Bread Loaf” profile. I have one intersecting wall at the top of the stairs. Making the handrail 2 pieces. The long going down stairs and short at the top of the stairs.
After finding the angel and making the compound miter cut, the top piece rotates away from the wall and wont sit square on a bracket???
Cant see what I’m doing wrong.
Please help, thanks.
View devann's profile
2246 posts in 2622 days
#1 posted 11-11-2011 02:52 AM
View cabmaker's profile
1706 posts in 2739 days
#2 posted 11-11-2011 06:24 AM
Is your long run on wall brackets or ballisters ? If on wall brackets they may not be at a true angle, thus when making the return may be canted or the return wall itself may be off. Or your mitre may not be cut true. These things only apply if Im understanding your description accuratly. Need more info. Are you attempting to compound a cut on the same stair line or are you returning to a wall ? If so youll need to level out the handrail before a 90 degree mitre or youll find that there is no compound cut available.
#3 posted 11-11-2011 05:40 PM
They are on wall brackets. Its an inside corner. SAme stair line.Like in the pic, it woud be the first cut coming up the stair. But it angels (140 deg.) and continues up then stops. Besides the simple end returns its the only compound miter.
View Jim Baldwin's profile
Jim Baldwin
56 posts in 2288 days
#4 posted 12-11-2011 11:46 PM
Rake angle compound miter joints are not possible in handrail, moldings or any trim pieces without modification of the actual profiles. Compound angled handrail segments are custom made to negotiate such transitions.
You are trying to do the “impossible”.
-- Jim Baldwin/
