Tips & Tricks: Woodworking Terminology
Forum topic by MsDebbieP posted 11-10-2011 11:49 AM 3535 views 1 time favorited 19 replies Add to Favorites Watch
18615 posts in 4124 days
11-10-2011 11:49 AM
Topic tags/keywords: terminology dictionary tips tricks
Let’s create a mini woodworking-dictionary:
  • name it
  • define it
(also add links to helpful blogs etc that are related to the topic)
Gateway to all Tips & Tricks Topics
19 replies so far
View WoodWoman's profile
WoodWoman
2 posts in 2362 days
#1 posted 11-10-2011 03:25 PM
Mortise & Tenon Joint : a woodworking joint that is made by inserting a tenon into a mortise.
Mortise: The cavity, whether square or round which accepts the fit of a like size and shaped tenon to form a joint.
Tenon: A projection at the end of a piece of wood that fits into a like size and shaped mortise to form a joint.
#2 posted 11-10-2011 04:37 PM
board foot: thickness x width x length divided by 144 equals board feet
here is a good discussion re: measuring when purchasing
View Gregn's profile
Gregn
1642 posts in 2947 days
#3 posted 11-10-2011 06:57 PM
Cook: To set aside a glue up while glue cures.
404 - Not Found
2544 posts in 2933 days
#4 posted 11-10-2011 11:23 PM
a few for the timber merchants
PAO = Planed all over
PSE = Planed square edge
cube = 12 board foot
wide plank = 9” and over at a premium
deal (red deal/white deal) a pine plank 2” or under by 10” or under (red = scots pine, white = norwegian pine)
View Mark's profile
Mark
1807 posts in 3238 days
#5 posted 11-10-2011 11:28 PM
2×4 = 1.5”x3.5”
-- M.K.
View Rick's profile
Rick
9432 posts in 2996 days
#6 posted 11-11-2011 11:07 AM
”Golden Ratio” Used to Design & Layout MANY Items including Woodwork. It also appears Naturally in Nature.
Wesh Love Spoons and Golden Ratio Caliper.
-- LIFE is what happens when you're planning on doing Other Things!
View Joe Lyddon's profile
Joe Lyddon
10046 posts in 4016 days
#7 posted 11-11-2011 10:39 PM
Wood magazine had one those little tools featured a few months back…
I made a few of them…
They’re very nice!
#8 posted 11-13-2011 06:14 PM
Heartwood – the centre part of the tree, typically harder than the rest of the tree (if I understand correctly)
Sapwood – the outer part of the tree (where the sap runs) and often softer than the rest of the wood (if I understand correctly) and usually a lighter colour
(See Sodbuster’s comment #17 below for better information)
#9 posted 11-13-2011 06:21 PM
Quarter sawn / Rift Sawn / Plain or Flat Sawn – how the lumber is milled.
Here is a great discussion re: the differences
#10 posted 11-14-2011 02:32 PM
Kerf – the cut size created by the size of the saw blade.
#11 posted 11-15-2011 03:53 PM
Cramp – A frame with an adjustable part, used to hold pieces together
Clamp -A tool with a screw at one end, used to hold wood together
Vise -A clamping devise with two jaws
View poopiekat's profile
poopiekat
4349 posts in 3698 days
#12 posted 11-15-2011 04:31 PM
I hope nobody posts that tedious glossary of twenty woodworking terms that begins: “Drill Press: a device for grabbing metal with sharp edges and throwing it across the room…..” Egads, it’s been posted enough times already….
View SeaWitch's profile
SeaWitch
149 posts in 2358 days
#13 posted 11-15-2011 05:24 PM
Caul = a wood strip used for clamping. A Caul is often planed so it is slightly bowed so that when it’s clamped down on the ends, the center maintains contact with the piece being clamped on. It’s usually used on several boards being glued together edge to edge so they all stay flat across the top.
-- When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it.”   Theodore Roosevelt
View ryno101's profile
ryno101
388 posts in 3628 days
#14 posted 11-16-2011 09:22 PM
One that I always forget regarding frame & panel construction…
Rails – The horizontal members of the frame Stiles – The vertical members of the frame
-- Ryno http://shawsheenwoodworks.com
View Sodbuster's profile
Sodbuster
45 posts in 3015 days
#15 posted 11-16-2011 11:42 PM
As to hardness and strength of heartwood vs sapwood, the answer is “sometimes”. Extractives in the wood sometimes create a color difference is some species, but in others, none at all. These extractives may cause a slight difference in compressive, shear, and hardness readings, but not a major amount. Color and resistance to decay, in some species, is the main difference.
Source – Textbook of Wood Technology, Panshin and DeZeeuw, pg.228 -231.
A lot of the old timers thought the sapwood was much weaker or softer. Just didn’t hold up to scientific testing.
-- M Clark, Georgia
